可是下载的时候总是跳出这样的对话框
WARNING: The file <main.dbg> is more recent than the corresponding absolute file.
Please recompile and link this source file before trying to debug.
Select OK to continue, CANCEL to avoid other out of date warnings for this application.(上传不了图片,只好敲上来了) 命令窗口会出现这样的提示: Preload Command File execution: preload.cmd File does not exist: preload.cmd Preload command file does not exist. Postload Command File execution: postload.cmd File does not exist: postload.cmd Postload command file does not exist.
不知道哪里设置的问题?? [此贴子已经被作者于2006-9-8 20:30:28编辑过]
[此贴子已经被作者于2006-9-8 20:42:34编辑过] |
