越来越觉得USB的世界是一个理想化的世界,在那里,一个设备可以有多种配置,做不同的事,过不一样的生活,而我们的配置永远只有一个,从生到死,没得选择。所谓的爱情的选择,职业的选择,在你选择过后再看,似乎冥冥中都有一种神秘的力量在支配着,而我们在其中只不过是上紧的发条,每个人自出生始就被配置了不同的路,你的彷徨,你的叛逆,你的伤心,你的快乐,都只不过是许多看似的偶然所组成的必然。
我不是宿命论者,我也经常在夜深人静不能入寐的时候回忆过去的悲欢与离合,惆怅现在的无助与无奈,思索将来要走的路。不过在爱成往事,烟花散尽后,过往的情形似乎都是不可逆转的必然。这就是所谓的人类一思考上帝就发笑吧,因为他知道你的努力都是徒劳,但是你还不得不去努力,这就是所谓的无奈的人生。
上帝又发笑了,还是接着看usb设备的配置吧,在include/linux/usb.h里定义
206 /**
207 * struct usb_host_config - representation of a device's configuration
208 * @desc: the device's configuration descriptor.
209 * @string: pointer to the cached version of the iConfiguration string, if
210 * present for this configuration.
211 * @interface: array of pointers to usb_interface structures, one for each
212 * interface in the configuration. The number of interfaces is stored
213 * in desc.bNumInterfaces. These pointers are valid only while the
214 * the configuration is active.
215 * @intf_cache: array of pointers to usb_interface_cache structures, one
216 * for each interface in the configuration. These structures exist
217 * for the entire life of the device.
218 * @extra: pointer to buffer containing all extra descriptors associated
219 * with this configuration (those preceding the first interface
220 * descriptor).
221 * @extralen: length of the extra descriptors buffer.
222 *
223 * USB devices may have multiple configurations, but only one can be active
224 * at any time. Each encapsulates a different operational environment;
225 * for example, a dual-speed device would have separate configurations for
226 * full-speed and high-speed operation. The number of configurations
227 * available is stored in the device descriptor as bNumConfigurations.
228 *
229 * A configuration can contain multiple interfaces. Each corresponds to
230 * a different function of the USB device, and all are available whenever
231 * the configuration is active. The USB standard says that interfaces
232 * are supposed to be numbered from 0 to desc.bNumInterfaces-1, but a lot
233 * of devices get this wrong. In addition, the interface array is not
234 * guaranteed to be sorted in numerical order. Use usb_ifnum_to_if() to
235 * look up an interface entry based on its number.
236 *
237 * Device drivers should not attempt to activate configurations. The choice
238 * of which configuration to install is a policy decision based on such
239 * considerations as available power, functionality provided, and the user's
240 * desires (expressed through userspace tools). However, drivers can call
241 * usb_reset_configuration() to reinitialize the current configuration and
242 * all its interfaces.
243 */
244 struct usb_host_config {
245 struct usb_config_descriptor desc;
246
247 char *string; /* iConfiguration string, if present */
248 /* the interfaces associated with this configuration,
249 * stored in no particular order */
250 struct usb_interface *interface[USB_MAXINTERFACES];
251
252 /* Interface information available even when this is not the
253 * active configuration */
254 struct usb_interface_cache *intf_cache[USB_MAXINTERFACES];
255
256 unsigned char *extra; /* Extra descriptors */
257 int extralen;
258 };
245行,desc,四大描述符里最后的一个终于出现了,同样是在它们的老巢include/linux/usb/ch9.h里定义
250 /* USB_DT_CONFIG: Configuration descriptor information.
251 *
252 * USB_DT_OTHER_SPEED_CONFIG is the same descriptor, except that the
253 * descriptor type is different. Highspeed-capable devices can look
254 * different depending on what speed they're currently running. Only
255 * devices with a USB_DT_DEVICE_QUALIFIER have any OTHER_SPEED_CONFIG
256 * descriptors.
257 */
258 struct usb_config_descriptor {
259 __u8 bLength;
260 __u8 bDescriptorType;
261
262 __le16 wTotalLength;
263 __u8 bNumInterfaces;
264 __u8 bConfigurationValue;
265 __u8 iConfiguration;
266 __u8 bmAttributes;
267 __u8 bMaxPower;
268 } __attribute__ ((packed));
269
270 #define USB_DT_CONFIG_SIZE 9
259行,bLength,描述符的长度,值为USB_DT_CONFIG_SIZE。
260行,bDescriptorType,描述符的类型,值为USB_DT_CONFIG,0x02。这么说对不对?按照前面接口描述符、端点描述符和设备描述符的习惯来说,应该是没问题。但是,生活总是会在我们已经习惯它的时候来个转折,这里的值却并不仅仅可以为USB_DT_CONFIG,还可以为USB_DT_OTHER_SPEED_CONFIG,0x07。这里说的OTHER_SPEED_CONFIG描述符描述的是高速设备操作在低速或全速模式时的配置信息,和配置描述符的结构完全相同,区别只是描述符的类型不同,是只有名字不同的孪生兄弟。
262行,wTotalLength,使用GET_DESCRIPTOR请求从设备里获得配置描述符信息时,返回的数据长度,也就是说对包括配置描述符、接口描述符、端点描述符,class-或vendor-specific描述符在内的所有描述符算了个总帐。
263行,bNumInterfaces,这个配置包含的接口数目。
263行,bConfigurationValue,对于拥有多个配置的幸运设备来说,可以拿这个值为参数,使用SET_CONFIGURATION请求来改变正在被使用的 USB配置,bConfigurationValue就指明了将要激活哪个配置。咱们的设备虽然可以有多个配置,但同一时间却也只能有一个配置被激活。捎带着提一下,SET_CONFIGURATION请求也是标准的设备请求之一,专门用来设置设备的配置。
265行,iConfiguration,描述配置信息的字符串描述符的索引值。
266行,bmAttributes,这个字段表征了配置的一些特点,比如bit 6为1表示self-powered,bit 5为1表示这个配置支持远程唤醒。另外,它的bit 7必须为1,为什么?协议里就这么说的,我也不知道,这个世界上并不是什么事情都找得到原因的。ch9.h里有几个相关的定义
272 /* from config descriptor bmAttributes */
273 #define USB_CONFIG_ATT_ONE (1 << 7) /* must be set */
274 #define USB_CONFIG_ATT_SELFPOWER (1 << 6) /* self powered */
275 #define USB_CONFIG_ATT_WAKEUP (1 << 5) /* can wakeup */
276 #define USB_CONFIG_ATT_BATTERY (1 << 4) /* battery powered */
267行,bMaxPower,设备正常运转时,从总线那里分得的最大电流值,以2mA为单位。设备可以使用这个字段向hub表明自己需要的的电流,但如果设备需求过于旺盛,请求的超出了hub所能给予的,hub就会直接拒绝,不会心软。你去请求她给你多一点点爱,可她心系天下人,没有多的分到你身上,于是怎么办?拒绝你呗,不要说爱情是多么残酷,这个世界就是很无奈。还记得struct usb_device结构里的bus_mA吗?它就表示hub所能够给予的。Alan Stern大侠告诉我们
(c->desc.bMaxPower * 2) is what the device requests and udev->bus_mA is what the hub makes available.
到此为止,四大标准描述符已经全部登场亮相了,还是回到struct usb_host_config结构的247行,string,这个字符串保存了配置描述符iConfiguration字段对应的字符串描述符信息。
250行,interface[USB_MAXINTERFACES],配置所包含的接口。注释里说的很明确,这个数组的顺序未必是按照配置里接口号的顺序,所以你要想得到某个接口号对应的struct usb_interface结构对象,就必须使用drivers/usb/usb.c里定义的usb_ifnum_to_if函数。
65 /**
66 * usb_ifnum_to_if - get the interface object with a given interface number
67 * @dev: the device whose current configuration is considered
68 * @ifnum: the desired interface
69 *
70 * This walks the device descriptor for the currently active configuration
71 * and returns a pointer to the interface with that particular interface
72 * number, or null.
73 *
74 * Note that configuration descriptors are not required to assign interface
75 * numbers sequentially, so that it would be incorrect to assume that
76 * the first interface in that descriptor corresponds to interface zero.
77 * This routine helps device drivers avoid such mistakes.
78 * However, you should make sure that you do the right thing with any
79 * alternate settings available for this interfaces.
80 *
81 * Don't call this function unless you are bound to one of the interfaces
82 * on this device or you have locked the device!
83 */
84 struct usb_interface *usb_ifnum_to_if(const struct usb_device *dev,
85 unsigned ifnum)
86 {
87 struct usb_host_config *config = dev->actconfig;
88 int i;
89
90 if (!config)
91 return NULL;
92 for (i = 0; i < config->desc.bNumInterfaces; i++)
93 if (config->interface[i]->altsetting[0]
94 .desc.bInterfaceNumber == ifnum)
95 return config->interface[i];
96
97 return NULL;
98 }
这个函数的道理很简单,就是拿你指定的接口号,和当前配置的每一个接口可选设置0里的接口描述符的bInterfaceNumber字段做比较,相等了,那个接口就是你要寻找的,都不相等,那对不起,不能满足你的要求,虽然它已经尽力了。
如果你看了协议,可能会在9.6.5里看到,请求配置描述符时,配置里的所有接口描述符是按照顺序一个一个返回的。那为什么这里又明确说明,让咱们不要期待它就会是接口号的顺序那?其实很久很久以前这里并不是这么说地,它就说这个数组是按照0..desc.bNumInterfaces的顺序,但同时又说需要通过usb_ifnum_to_if函数来获得指定接口号的接口对象,Alan Stern大侠质疑了这种有些矛盾的说法,于是David Brownell大侠就把它改成现在这个样子了,为什么改?因为协议归协议,厂商归厂商,有些厂商就是有不遵守协议的癖好,它非要先返回接口1再返回接口0,你也没辙,所以就不得不增加usb_ifnum_to_if函数。
USB_MAXINTERFACES是drivers/usb/usb.h里定义的一个宏,值为32,不要说不够用,谁见过有很多接口的设备?
/* this maximum is arbitrary */
#define USB_MAXINTERFACES 32
254行,intf_cache[USB_MAXINTERFACES],cache是什么?缓存。答对了,不然大学四年岂不是光去吃老赵烤肉了。这是个struct usb_interface_cache对象的结构数组,usb_interface,usb接口,cache,缓存,所以usb_interface_cache就是usb接口的缓存。缓存些什么?看看include/linux/usb/usb.h里的定义
179 /**
180 * struct usb_interface_cache - long-term representation of a device interface
181 * @num_altsetting: number of altsettings defined.
182 * @ref: reference counter.
183 * @altsetting: variable-length array of interface structures, one for
184 * each alternate setting that may be selected. Each one includes a
185 * set of endpoint configurations. They will be in no particular order.
186 *
187 * These structures persist for the lifetime of a usb_device, unlike
188 * struct usb_interface (which persists only as long as its configuration
189 * is installed). The altsetting arrays can be accessed through these
190 * structures at any time, permitting comparison of configurations and
191 * providing support for the /proc/bus/usb/devices pseudo-file.
192 */
193 struct usb_interface_cache {
194 unsigned num_altsetting; /* number of alternate settings */
195 struct kref ref; /* reference counter */
196
197 /* variable-length array of alternate settings for this interface,
198 * stored in no particular order */
199 struct usb_host_interface altsetting[0];
200 };
199行的altsetting[0]是一个可变长数组,按需分配的那种,你对设备说GET_DESCRIPTOR的时候,内核就根据返回的每个接口可选设置的数目分配给intf_cache数组相应的空间,有多少需要多少分配多少,在咱们还在为拥有一套房而奋斗终生的时候,这里已经提前步入了共产主义。
为什么要缓存这些东东?房价在变,物价在变,设备的配置也在变,此时这个配置可能还在欢快的被宠幸着,彼时它可能就躲在冷宫里写《后宫回忆录》,漫长的等待之后,哪个导演慧眼识剧本发现了它,她就又迎来了自己的第二春。这就叫此一时彼一时。为了在配置被取代之后仍然能够获取它的一些信息,就把日后可能会需要的一些东东放在了intf_cache数组的struct usb_interface_cache对象里。谁会需要?这么说吧,你通过sysfs这个窗口只能看到设备当前配置的一些信息,即使是这个配置下面的接口,也只能看到接口正在使用的那个可选设置的信息,可是你希望能够看到更多的,怎么办,窗户太小了,可以趴门口看,usbfs就是这个门,里面显示有你的系统中所有usb设备的可选配置和端点信息,它就是利用intf_cache这个数组里缓存的东东实现的。
256行,extra,257行,extralen,有关额外扩展的描述符的,和struct usb_host_interface里的差不多,只是这里的是针对配置的,如果你使用GET_DESCRIPTOR请求从设备里获得配置描述符信息,它们会紧跟在标准的配置描述符后面返回给你。
