SIMULATION LOG ============== Design: E:\基于80C51的供电系统数据采集和处理\基于80C51的供电系统数据采集和处理.DSN Doc. no.: <NONE> Revision: <NONE> Author: <NONE> Created: 06/09/08 Modified: 06/09/10
Compiling source files... Build completed OK. Compiling netlist... Linking netlist... Partition analysis...
Simulating partition 1 [31E43194]... Animation started sucessfully... PROSPICE Release 6.7 SP0 (C) Labcenter Electronics 1993-2005. SPICE Kernel Version 3f5. (C) Berkeley University ERL.
Reading netlist... Reading SPICE models... Loading library 'ANALOGD.SML' Loading library 'APEX.SML' Loading library 'BURRBROWN.SML' Loading library 'ELANTEC.SML' Loading library 'FAIRCHLD.SML' Loading library 'INTERSIL.SML' Loading library 'LINTEC.SML' Loading library 'NATOA.SML' Loading library 'SUPERTEX.SML' Loading library 'TECCOR.SML' Loading library 'TEX101.SML' Loading library 'TEX301.SML' Loading library 'TEX3_1.SML' Loading library 'TEX401.SML' Loading library 'TEX5_1.SML' Loading library 'VALVES.SML' Loading library 'ZETEX.SML' Building circuit... Instantiating SPICE models... [U1] Loading HEX file 'C:\Keil\8051\8051.hex'. [U1] Read total of 122 bytes from file 'C:\Keil\8051\8051.hex'. [SPICE] Error 106 - TRAN: Timestep too small; time = 1.6365e-006, timestep = 1.25e-019: trouble with node "7SEG-COM-ANODE#0031_IP5#branch" . Real Time Simulation FAILED.
请大家帮帮忙!!!解决一下这个错误!!!谢谢!!! |
