DSP按键程序问题
DSP按键程序问题
#include"DSP2833x_Device.h"     // DSP2833x HeaderfileInclude File
#include "DSP2833x_Examples.h"   // DSP2833x ExamplesInclude File
端口宏定义
#define  key5 GpioDataRegs.GPADAT.bit.GPIO4
#define  key6 GpioDataRegs.GPADAT.bit.GPIO5
#define  key7 GpioDataRegs.GPADAT.bit.GPIO6
#define  key8 GpioDataRegs.GPADAT.bit.GPIO7
定义全局变量
unsigned short flag1=0,flag2=0,flag3=0,flag4=0;
声明函数
void scan_key(void);
void manage_key1(void);
void manage_key2(void);
void manage_key3(void);
void manage_key4(void);
void Gpio_select(void);
主函数
void main(void)
  InitSysCtrl();
   DINT;
  Gpio_select() ;
// Initialize the PIE control registers to their default state.
// The default state is all PIE interrupts disabled and flags
// are cleared.
// This function is found in the DSP2833x_PieCtrl.c file.
  InitPieCtrl();
// Disable CPU interrupts and clear all CPU interrupt flags:
   IER = 0x0000;
   IFR = 0x0000;
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
// This will populate the entire table, even if the interrupt
// is not used in this example.  This is useful for debug purposes.
// The shell ISR routines are found in DSP2833x_DefaultIsr.c.
// This function is found in DSP2833x_PieVect.c.
   InitPieVectTable();
   InitXintf();
   key5=0;
   key6=0;
   key7=0;
   key8=0;
  while(1)
  if((key5==1)|(key6==1)|(key7==1)|(key8==1))
   scan_key();
按键查询
void scan_key()
  unsigned int  i;
  for(i=0;i<10000;i++){};//
去抖动
  if(key5==1)
        manage_key1();
   else if(key6==1)
        manage_key2();
   else if(key7==1)
        manage_key3();
   else if(key8==1)
        manage_key4();
void manage_key1()
flag1=3;
key5=0;
void manage_key2()
flag2=6;
key6=0;
void manage_key3()
flag3=9;
key7=0;
void manage_key4()
flag4=0;
key8=0;
EALLOW;
GpioCtrlRegs.GPAMUX1.all=0x0000;
GpioCtrlRegs.GPADIR.all=0xf000;   //GPIO PORTs as output
GpioCtrlRegs.GPAQSEL1.all= 0x0000;    // Set GPIO input qualifiervalues
EDIS;
四个按键,flag1~4分别对应,每次按下相应按键后,flag的值加1,但是现在的问题是初始以后flag的值就不是0,而且按下按键后也不加1.
首先确认你的Gpio_select()里面IO口的配置是否合理
然后建议你将main函数中的Gpio_select()放到中断处理完之后试试
做人要做懒羊羊啊!
