求助ide的问题
求助ide的问题
我刚用nios2,想做个小系统,但用ide时,用他自带的例程编译时出现以下错误:
Severity Description Resource In Folder Location Creation Time
2 *** [obj/alt_busy_sleep.o] Error 1 hello_led_0   September 25, 2006 12:16:10 AM
2 *** [system_project] Error 2 hello_led_0   September 25, 2006 12:16:10 AM
2 error: parse error before '/' token[/cygdrive/c/altera/kits/nios2/components/altera_nios2/HAL/src/alt_busy_sleep.c] hello_led_0  line 69 September 25, 2006 12:16:10 AM
2 error: parse error before '/' token[/cygdrive/c/altera/kits/nios2/components/altera_nios2/HAL/src/alt_busy_sleep.c] hello_led_0  line 89 September 25, 2006 12:16:10 AM
2 error: parse error before '/' token[/cygdrive/c/altera/kits/nios2/components/altera_nios2/HAL/src/alt_busy_sleep.c] hello_led_0  line 106 September 25, 2006 12:16:10 AM
2 error: parse error before ')' token[/cygdrive/c/altera/kits/nios2/components/altera_nios2/HAL/src/alt_busy_sleep.c] hello_led_0  line 106 September 25, 2006 12:16:10 AM
2 error: parse error before '/' token[/cygdrive/c/altera/kits/nios2/components/altera_nios2/HAL/src/alt_busy_sleep.c] hello_led_0  line 123 September 25, 2006 12:16:10 AM
2 error: parse error before ')' token[/cygdrive/c/altera/kits/nios2/components/altera_nios2/HAL/src/alt_busy_sleep.c] hello_led_0  line 123 September 25, 2006 12:16:10 AM
2 *** [obj/alt_busy_sleep.o] Error 1 hello_led_0_syslib   September 25, 2006 12:16:03 AM
2 error: parse error before '/' token[/cygdrive/c/altera/kits/nios2/components/altera_nios2/HAL/src/alt_busy_sleep.c] hello_led_0_syslib  line 69 September 25, 2006 12:16:03 AM
2 error: parse error before '/' token[/cygdrive/c/altera/kits/nios2/components/altera_nios2/HAL/src/alt_busy_sleep.c] hello_led_0_syslib  line 89 September 25, 2006 12:16:03 AM
2 error: parse error before '/' token[/cygdrive/c/altera/kits/nios2/components/altera_nios2/HAL/src/alt_busy_sleep.c] hello_led_0_syslib  line 106 September 25, 2006 12:16:03 AM
2 error: parse error before ')' token[/cygdrive/c/altera/kits/nios2/components/altera_nios2/HAL/src/alt_busy_sleep.c] hello_led_0_syslib  line 106 September 25, 2006 12:16:03 AM
2 error: parse error before '/' token[/cygdrive/c/altera/kits/nios2/components/altera_nios2/HAL/src/alt_busy_sleep.c] hello_led_0_syslib  line 123 September 25, 2006 12:16:03 AM
2 error: parse error before ')' token[/cygdrive/c/altera/kits/nios2/components/altera_nios2/HAL/src/alt_busy_sleep.c] hello_led_0_syslib  line 123 September 25, 2006 12:16:03 AM
1 Error launching external scanner info generator (make -s -C Debug listincludedirs) hello_led_0   September 25, 2006 12:35:40 AM
1 Error launching external scanner info generator (make -s -C Debug listincludedirs) hello_led_0_syslib   September 25, 2006 12:35:40 AM
请问这是设置的问题吗?
还有各位大虾能不能给小弟介绍一下相关的参考资料,我的邮箱wanghaifeng_0413@163.com
谢谢了!
每一天都是新的开始,每一天都有新的收获
代码贴上来看看,是不是你的工程建立有问题,或者是你的安装有问题
在交流中前进,共同实现nios的应用。
Component: alt_busy_sleep 的驅動程序有語法錯誤,也可能是cpu的系統庫文件出錯了,檢查別的系統,和system.h頭文件可能會有幫助
-= UESTC - legendbb =-
