ucos II+ucGUI+s3c2410+LCD+触摸屏整合02
5、某些编译器(如:ads1.2)不会初始化全局变量,因此做如下事:
1) 修改如下函数为:(位于GUICore.c)
static void _InitContext(GUI_CONTEXT* pContext) {
memset(pContext,0,sizeof(GUI_CONTEXT));//add
#if GUI_SUPPORT_MEMDEV
GUI_SelectLCD();
#else
LCD_SetClipRectMax();//LCD_L0_GetRect
#endif
pContext->pLCD_HL = &LCD_HL_APIList;
pContext->pAFont = GUI_DEFAULT_FONT;
pContext->pClipRect_HL = &GUI_Context.ClipRect;
pContext->PenSize = 1;
pContext->DrawMode = GUI_DRAWMODE_NORMAL;//add
pContext->TextMode = GUI_TEXTMODE_NORMAL;//add
pContext->TextAlign = GUI_TA_LEFT|GUI_TA_TOP;//add
pContext->AA_HiResEnable = 0;//add
/* Variables in WM module */
#if GUI_WINSUPPORT
pContext->hAWin = WM_GetDesktopWindow();
#endif
/* Variables in GUI_AA module */
pContext->AA_Factor = 3;
LCD_SetBkColor(GUI_DEFAULT_BKCOLOR);
LCD_SetColor(GUI_DEFAULT_COLOR);
修改如下函数为:(位于GUIAlloc.c)
void GUI_ALLOC_Init(void) {
GUI_ALLOC.NumUsedBytes = 0;
memset(&aBlock,0,sizeof(aBlock[0])*GUI_MAXBLOCKS);/////self
aBlock[0].Size = (1<<GUI_BLOCK_ALIGN); /* occupy minimum for a block */
修改如下函数为:(位于WM.c)(――――――――――New)
void WM_Init(void) {
if (!_IsInited) {
memset(&_ClipContext,0,sizeof(WM_IVR_CONTEXT));//add
NextDrawWin = WM__FirstWin = WM_HWIN_NULL;
_IsInited =1;
2)自己编写如下函数(ads1.2):
void MyInit()
IsInitialized = 0;//MemDev
_IsInited = 0;//Win
WM__CreateFlags = 0;
GUI_CURSOR_pfTempHide = NULL;
GUI_Context.hDevData = 0;
WM__hCapture=0;
WM__hWinFocus=0;
WM_pfPollPID = 0;
WM_pfHandlePID = 0;
GUI_pfTimerExec = 0;
_KeyMsgCnt = 0;
该函数应在GUI_Init()调用之前调用。
6、改写GUI_Init()函数:
int GUI_Init(void) {
int r;
GUI_DEBUG_LOG("\nGUI_Init()");
/* Init system wide globals first */
GUI_DecChar = '.';
/* Init context */
_InitContext(&GUI_Context);
GUITASK_INIT();
r = LCD_Init();
#if GUI_WINSUPPORT
WM_Init();
#endif
GUITASK_COPY_CONTEXT();
GUI_Clear();
GUI_X_Init();
GUI_CURSOR_Show();//启动即显示鼠标
return r;
三、ucGUI与ucOS的整合,主要修改GUI_X.c文件:
1、定义信号量及全局量:
static OS_EVENT *DispSem;
static OS_EVENT *EventMbox;
static OS_EVENT *KeySem;
static int KeyPressed;
static char KeyIsInited;
2、实现结合函数:
int GUI_X_GetTime(void)
return ((int)OSTimeGet());
void GUI_X_Delay(int period)
INT32U ticks;
ticks = (period * 1000) / OS_TICKS_PER_SEC;
OSTimeDly((INT16U)ticks);
void GUI_X_Unlock(void)
OSSemPost(DispSem);
void GUI_X_Lock(void)
U8 err;
OSSemPend(DispSem, 0, &err);
U32 GUI_X_GetTaskId(void)
return ((U32)(OSTCBCur->OSTCBPrio));
void GUI_X_WaitEvent (void)
INT8U err;
(void)OSMboxPend(EventMbox, 0, &err);
void GUI_X_SignalEvent (void)
(void)OSMboxPost(EventMbox, (void *)1);
void GUI_X_InitOS(void)
DispSem = OSSemCreate(1);
EventMbox = OSMboxCreate((void *)0);
void GUI_X_ExecIdle(void) {GUI_X_Delay(1);}
void GUI_X_Init(void) {
SetTSInterrupt();//此处接入触摸屏的中断设置
GUI_TOUCH_SetDefaultCalibration();//用默认值校准触摸屏
四、与触摸屏有关的函数:
1、4个功能函数:
void GUI_TOUCH_X_ActivateX(void) {//空}
void GUI_TOUCH_X_ActivateY(void) {//空}
int GUI_TOUCH_X_MeasureX(void) {
return TX;//返回触摸坐标x
int GUI_TOUCH_X_MeasureY(void){
return TY; //返回触摸坐标y
2、触摸屏校准任务(进程, 来自示例程序:TOUCH_Calibrate.c):
#if TOUCH_NEED_CALIBRATE
static const char * _acPos[] = {
"(upper left position)",
"(lower right position)"
static void _WaitForPressedState(int Pressed) {
GUI_PID_STATE State;
/* Wait until touch is pressed */
do {
GUI_TOUCH_GetState(&State);
if (State.Pressed == Pressed) {
break;
GUI_Delay (100);
} while (1);
static void _DispStringCentered(const char * pString) {
GUI_RECT Rect;
Rect.x0 = Rect.y0 = 0;
Rect.x1 = LCD_GetXSize() - 1;
Rect.y1 = LCD_GetYSize() - 1;
GUI_DispStringInRect(pString, &Rect, GUI_TA_HCENTER | GUI_TA_VCENTER);
static void _GetPhysValues(int LogX, int LogY, int * pPhysX, int * pPhysY, const char * pString) {
char acText[] = "Press here";
GUI_RECT Rect;
int FontSizeY, Align;
FontSizeY = GUI_GetFontSizeY();
GUI_Clear();
GUI_SetColor(GUI_BLACK);
_DispStringCentered("Runtime calibration,\n"
"please touch the screen\n"
"at the center of the ring."); /* Ask user to press the touch */
/* Calculate the rectangle for the string */
Rect.y0 = LogY - FontSizeY;
Rect.y1 = LogY + FontSizeY;
if (LogX < LCD_GetXSize() / 2) {
Rect.x0 = LogX + 15;
Rect.x1 = LCD_GetXSize();
Align = GUI_TA_LEFT;
} else {
Rect.x0 = 0;
Rect.x1 = LogX - 15;
Align = GUI_TA_RIGHT;
