芯片是2c5t144c8 在ide中运行程序出现如下提示,请高手帮帮忙 Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK Downloading 00100020 ( 0%) Downloaded 6KB in 0.1s Verifying 00100020 ( 0%) Verify failed between address 0x100020 and 0x101733 Leaving target processor paused
