CPLD双向I/O口问题请教!(重新整理) [求助]
VHDL程序如下:
该程序主要完成将CPU传送过来的8位命令经CPU转换为串行信号经SDATA输出并回读串行接口芯片返回的数据,由SCLK提供50M时钟!其中
gclk : 外部100M时钟输入
en_ser : CPU发给CPLD的脉冲信号;第一个上升沿: 锁存CPU并行输出的命令数据,经COM_DATA口所存到COM_CPU。
第二个上升沿: 设置start_ser为高,CPLD启动clk_count计数SCLK开始输出
16个周期50M方波信号,SDATA前8个时钟串行输出COM_CPU命令,
后8个周期回读接口芯片返回的数据并锁存到DATA_RET中。
第三个上升沿: CPLD通过COM_DATA口将接口芯片返回的数据回送给CPU,由CPU对
数据进行处理.
com_dada: CPU与CPLD 8BIT 双向数据接口。
sdata : CPLD与串行接口芯片的双向数据线。
sden : 串行接口芯片使能信号。
LIBRARY IEEE;
USEIEEE.Std_logic_1164.ALL;
ENTITY flipchip IS
PORT(
gclk:INStd_Logic;
en_ser:IN Std_Logic:='0';
com_data:INOUTStd_Logic_vector(7 DOWNTO 0);
sdata:INOUTStd_Logic:='0';
sden:OUTStd_Logic:='0';
sclk:OUTStd_Logic:='0');
END flipchip;
ARCHITECTURE behave OF flipchip IS
SIGNALcom_cpu: STD_LOGIC_VECTOR(7 DOWNTO 0); --Buffered Command from CPU
SIGNALdata_cpu: STD_LOGIC_VECTOR(7 DOWNTO 0); --Buffered Set_Data from CPU
SIGNALdata_ret:STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL start_ser:STD_LOGIC :='0';
BEGIN
P_Sclk:
PROCESS(start_ser,gclk)
VARIABLE clk_count:INTEGER RANGE -1 TO 35 :=0;
BEGIN
IF(start_ser='0') THEN --Count Gclk
clk_count:=-1;
ELSIF(gclk'EVENT AND gclk='1')THEN
IF(clk_count/=35) THEN
clk_count:=clk_count+1;
END IF;
--Read Mode
CASE clk_count IS
WHEN 0 =>sclk<='0';
sden<='1';
sdata<='0';
WHEN 1 => sclk<='0';
sden<='1';--Enable Serial Communication Signal
sdata<=com_cpu(0);
WHEN 2 =>sclk<='1';--1
WHEN 3=> sclk<='0';
sdata<=com_cpu(1);
WHEN 4=> sclk<='1';--2
WHEN 5 => SCLK<='0';
sdata<=com_cpu(2);
WHEN 6 => sclk<='1';--3
WHEN 7 => sclk<='0';
sdata<=com_cpu(3);
WHEN 8 => sclk<='1';--4
WHEN 9 => sclk<='0';
sdata<=com_cpu(4);
WHEN 10=>sclk<='1';--5
WHEN 11=> SCLK<='0';
sdata<=com_cpu(5);
WHEN 12=> sclk<='1';--6
WHEN 13=> sclk<='0';
sdata<=com_cpu(6);
WHEN 14=> sclk<='1';--7
WHEN 15=> sclk<='0';
sdata<=com_cpu(7);
WHEN 16=> sclk<='1';--8
sdata<=com_cpu(7);
sdata<='Z';
WHEN 17=> sclk<='0';
data_ret(0)<=sdata;
WHEN 18=> sclk<='1';--9
WHEN 19=> sclk<='0';
data_ret(1)<=sdata;
WHEN 20 => sclk<='1';--10
WHEN 21=> sclk<='0';
data_ret(2)<=sdata;
WHEN 22=> sclk<='1';--11
WHEN 23=> sclk<='0';
data_ret(3)<=sdata;
WHEN 24=> sclk<='1';--12
WHEN 25=> sclk<='0';
data_ret(4)<=sdata;
WHEN 26=> sclk<='1';--13
WHEN 27=> sclk<='0';
data_ret(5)<=sdata;
WHEN 28=> sclk<='1';--14
WHEN 29=> sclk<='0';
data_ret(6)<=sdata;
WHEN 30=> sclk<='1';--15
WHEN 31=> sclk<='0';
data_ret(7)<=sdata;
WHEN 32=> sclk<='1';--16
WHEN 33 TO 34=>sclk<='0';
sdata<='0';
WHEN 35=>sclk<='0';
sdata<='0';
sden<='0';
WHEN others=>sclk<='0';
sdata<='0';
END CASE;
END IF;--End gclk
END PROCESS P_Sclk;
latch_up_com:--Latch the Set_Command from CPU
PROCESS(en_ser)
VARIABLE count_en_ser: INTEGER RANGE -1 TO 2 :=-1;
BEGIN
IF(en_ser'EVENT AND en_ser='1') THEN
IF(count_en_ser=2) THEN
count_en_ser:=0;
en_out<='0';
ELSE
count_en_ser:=count_en_ser+1;
en_out<='0';
END IF;
ENDIF;
--Read Input Command_Data TO Buffer
CASE count_en_ser IS
WHEN 0 =>start_ser<='0';
com_data<="ZZZZZZZZ";
com_cpu<=com_data;
WHEN 1 =>start_ser<='1';
WHEN2 =>start_ser<='0';
com_data<=data_ret;
WHEN OTHERS =>start_ser<='0';
com_data<=data_ret;
END CASE;
END PROCESS latch_up_com;
END behave;
因SCLK时钟高达50M,在SCLK及SDATA输出时CPU无法干预SDATA的输入输出状态,只能由CPLD控制
SDATA模式切换,所以即使CPLD有输出使能控制信号OE,CPU也无法控制。
现在主要是该串行通信功能实现,小弟折腾了一个月也没有结果,急啊!
现在时间很紧,不知各位大侠能否指点菜鸟!不胜感激!! |
