WINCE PB编译不过各种错误集锦 02
最后提示的错误:
    Build for Windows CE (Release) (Built on Apr 14 2005 13:54:39)
    File names: Build.log Build.wrn Build.err Build.dat
    CEBUILD: Running sysgen -p wceshellfe preproc
    Starting sysgen phase for project ( wceshellfe )
    Sysgening platform C:WINCE500platformsmdk2450
    WINCE500build.err
    C:WINCE500build.err
    C:WINCE500build.log
    C:WINCE500build.wrn
    已复制        3 个文件.
    BLDDEMO: There were errors building 2450_p900
    2450_p900 - 3 error(s), 10 warning(s)
    这个问题比较麻烦,我通过重装系统(换用另外一张堞装,非ghost),成功过一次,换用台式机,也成功过.但是笔记本上后来又不行了,原因不明.
    四B编译提示don't know how to make.........................
    编译2450 bootloader出错,编译driver没错,
    编译Eboot错误如下:
    BUILD: [01:0000000039ROGC ] Compiling .debug.c
    BUILD: [01:0000000042ROGC ] Compiling .ether.c
    BUILD: [01:0000000045ROGC ] Compiling .flash.c
    BUILD: [01:0000000048ROGC ] Compiling .nand.cpp
    BUILD: [01:0000000051ROGC ] Compiling .usb.c
    BUILD: [01:0000000054ROGC ] Assembling .usbs.s
    BUILD: [00:0000000060ROGC ] Linking WINCE500PLATFORMSMDK2450SrcBootloaderEboot.Whimory directory.
    BUILD: [01:0000000067:ERRORE] NMAKE :  U1073: don't know how to make 'E:WINCE500platformsmdk2450libarmV4Iretailoal_memory_s3c2450.lib'
    BUILD: [01:0000000069:ERRORE] NMAKE.EXE  -i -c BUILDMSG=Stop.  LINKONLY=1 NOPASS0=1 failed - rc = 2
    BUILD: [00:0000000070ROGC ]                      Files      Warnings      Errors
    BUILD: [00:0000000071ROGC ] Midl                    0            0          0
    BUILD: [00:0000000072:PROGC ] Resource                0            0          0
    BUILD: [00:0000000073:PROGC ] Message                  0            0          0
    BUILD: [00:0000000074:PROGC ] Precomp Header          0            0          0
    BUILD: [00:0000000075:PROGC ] C/Cpp/Cxx                6            2          0
    BUILD: [00:0000000076:PROGC ] Assembler                3            0          0
    BUILD: [00:0000000077:PROGC ] Static Libraries        0            0          0
    BUILD: [00:0000000078:PROGC ] Dll's                    0            0          0
    BUILD: [00:0000000079:PROGC ] Exe's                    0            0          0
    BUILD: [00:0000000080:PROGC ] Resx                    0            0          0
    BUILD: [00:0000000081:PROGC ] Csharp Targets          0            0          0
    BUILD: [00:0000000082:PROGC ] Other                    0            0          2
    BUILD: [00:0000000083:PROGC ]
    BUILD: [00:0000000084:PROGC ] Total                    9            2          2
    BUILD: [00:0000000085:PROGC ]
    BUILD: [00:0000000086:PROGC ] 2 Warnings,  2 Errors
    2450_p900 - 2 error(s), 2 warning(s)
    我按照提示的路径找不着这个静态库,oal_memory_s3c2450.lib
    难道这个静态库PB装时给漏掉了?
    后来重装WINCE,打04,05,06,07年的补丁,问题依旧.看来还是没经验啊,感谢CSDN的高手Veabol,编译SrcCommon后,果真生成了oal_memory_s3c2450.lib.
    可是又出来一个CS8900*.lib的静态库,后面的字符不记得了,看来还有其他地方要生成该库.编译整个SMDK2450工程,看提示估计是该静态库是生成了,但是又
    弹出另外一个对话框,提示某文件无法编译,该文件为我已前做好的备份文件,有中文名.删除该文件后,再编译,仍然提示该错,将BSP根目录的build.dat删除,
    再编译,问题彻底解决.
    看来很多静态库不是PB装好后本身就有的,而需要编译一些代码才能生成.
