AT88SC0104C芯片的解密特性介绍
Features
• One of a Family of Devices with User Memories from 1 Kbit to 256-Kbit
• 1-Kbit (128-byte) EEPROM User Memory
  – Four 32 byte (256 bit) Zones
  – Self-timed Write Cycle
  – Single Byte or 16-byte Page Write Mode
  – Programmable Access Rights for Each Zone
• 2-Kbit Configuration Zone
  – 37-byte OTP Area for User-defined Codes
  – 160-byte Area for User-defined Keys and Passwords
• High Security Features
  – 64-bit Patented Dynamic Symetric Mutual Authentication Protocol
  – Encrypted Checksum
  – Stream Encryption
  – Four Key Sets for Authentication and Encryption
  – Eight Sets of Two 24-bit Passwords
  – Anti-tearing Function
  – Voltage and Frequency Monitor
• Smart Card Features
  – ISO 7816 Class A (5V) or Class B (3V) Operation
  – ISO 7816-3 Asynchronous T = 0 Protocol (Gemplus®atent)
  – Multiple Zones, Key Sets and Passwords for Multi-application Use
  – Synchronous 2-wire Serial Interface for Faster Device Initialization
  – Programmable 8-byte Answer-To-Reset Register
  – ISO 7816-2 Compliant Modules
• Embedded Application Features
  – Low Voltage Operation: 2.7V to 5.5V
  – Secure Nonvolatile Storage for Sensitive System or User Information
  – 2-wire Serial Interface
  – 1.5 MHz Compatibility for Fast Operation
  – Standard 8-lead Plastic Packages
  – Same Pinout as 2-wire Serial EEPROM's
• High Reliability
  – Endurance: 100,000 Cycles
  – Data Retention: 10 years
  – ESD Protection: 4,000V min
欢迎广大有解密需求的客户随时与我取得联系。电话:15313166209  QQ:1002668449
单片机解密,周期短、价格低 http://www.cy8c37.com
电话:15313166209
