关于Linux2.6.34下DM9000网卡驱动移植详解
作者:徐老师 凌阳教育嵌入式培训高级讲师
    DM9000是10/100M自适应的总线型网卡,Linux中对其支持已经非常完善,不同开发板之间移植、修改主要集中在总线的选择及中断选择上
    1)修改arch/arm/mach-s3c2440/mach-smdk2440.c文件,增加以下信息
    /****add by dengwei*********************************/
    #include
    static struct resource s3c_dm9k_resource[] =
    [0] =
    .start = S3C2410_CS3,      //网卡连接在CS3总线上(此处跟据不同开发板进行修改)
    .end = S3C2410_CS3 + 3,
    .flags = IORESOURCE_MEM,
    [1] =
    .start = S3C2410_CS3 + 4,   //同上
    .end = S3C2410_CS3 + 4 + 3,
    [2] = {
    .start = IRQ_EINT7,                //根据硬件外部中断管脚修改此数字
    .end = IRQ_EINT7,
    .flags = IORESOURCE_IRQ | IRQF_TRIGGER_RISING,
    static struct dm9000_plat_data s3c_dm9k_platdata =
    .flags =DM9000_PLATF_16BITONLY,
    struct platform_device s3c_device_dm9k =
    .name = "dm9000",
    .id = 0,
    .num_resources = ARRAY_SIZE(s3c_dm9k_resource),
    .resource = s3c_dm9k_resource,
    .dev =
    .platform_data= &s3c_dm9k_platdata,
    EXPORT_SYMBOL(s3c_device_dm9k);
/*************************add by dengwei***************************/
    2修改 arch/arm/mach-s3c2440/mach-smdk2440.c文件
    修改struct platform_device *smdk2440_devices[]__initdata结构体增加以下代码:
    static struct platform_device*smdk2440_devices[] __initdata =
    &s3c_device_ohci,
    &s3c_device_lcd,
    &s3c_device_wdt,
    &s3c_device_i2c0,
    &s3c_device_iis,
    &s3c_device_dm9k,            //for dm9000   add by dengwei
    3)修改drivers/net/dm9000.c源码
    在头文件区增加头文件:
    #include
    大约1365行左右增加以下代码:
    static int __devinit dm9000_probe(structplatform_device *pdev)
    //add   here  函数开始处
    /**********add by dengwei******************************************/
    [cpp] view plaincopy
    #if defined(CONFIG_ARCH_S3C2440)
    int oldval_bwscon = *((volatile unsignedint *)S3C2410_BWSCON);
    *((volatileunsigned int *)S3C2410_BWSCON)=(oldval_bwscon&~(3<<16))|S3C2410_BWSCON_DW3_16|S3C2410_BWSCON_WS3|S3C2410_BWSCON_ST3; //设置BANK3:总线宽度为16,使能nWAIT
    *((volatile unsigned int *)S3C2410_BANKCON3) = 0x1f7c; //设置BANK3的时间参数
    #endif
/**********add by dengwei****************/
    4)修改make menuconfig配置选项:
    Devices  Drivers --->
    Network device support--->
    Ethernet (10 or 100) --->
  • DM9000support
        (4)DM9000maxinum   debug level
    //仅保留这两个选项,其余的全部去掉
        5)重新编译内核,烧入开发板中即可
        6)第一次使用的开发板需使用ifconfig eth0 hw ether 12:34:56:78:32:65 设置mac地址
        (MAC地址可以随便设置)
        使用ifconfigeth0 192.168.220.*设置开发板IP
        使用ping命令ping主机即可
  • 返回列表
