请教高手,编译出错
请教高手,编译出错
出现以下问题,小弟解决不了请高手帮忙
ISE Auto-Make Log File
Updating: Generate PROM File
Starting: 'exewrap @__ednTOngd_exewrap.rsp'
Starting: 'ngdbuild -f __ngdbuild.rsp '
Release 4.1WP3.x - ngdbuild E.33
Copyright (c) 1995-2001 Xilinx, Inc.  All rights reserved.
ERRORortability:138 - Invalid file format, check the command argument file
   "__ngdbuild.rsp".
Usage: ngdbuild [-p <partname>] {-sd <source_dir>} {-l <library>} [-ur
<rules_file[.urf]>] [-dd <output_dir>] [-r] [-a] [-u] [-nt timestamp|on|off]
[-uc <ucf_file[.ucf]>] [-aul] [-i] [-modular initial|module|assemble] [-quiet]
[-verbose] [-active <active_module_name>] [-pimpath <pimpath>] {-use_pim
<pim_module_name>} <design_name> [<ngd_file[.ngd]>]
      -p  partname     Use specified part type to implement the design
      -sd source_dir   Add "source_dir" to the list of directories
                       to search when resolving netlist file references
      -l library       Add "library" to the list of source libraries
                       passed to the netlisters
      -ur rules_file   User rules file for netlist launcher
      -dd output_dir   Directory to place intermediate .ngo files
      -nt value        NGO file generation
                       Options:       "timestamp", "on", "off"
                       -nt timestamp: Regenerate NGO only when source
                                      netlist is newer than existing
                                      NGO file (default)
                       -nt on:        Always regenerate NGO file from
                                      source design netlists
                       -nt off:       Do not regenerate NGO files
                                      which already exist. Build NGD
                                      file from existing NGO files
      -uc ucf_file     Use specified "User Constraint File".
                       The file <design_name>.ucf is used by default
                       if it is found in the local directory.
      -r               Ignore location constraints
      -aul             Allow unmatched LOC constraints
      -a               Infer pad components from ports in top-level EDIF
                       netlist (if any)
      -i               Ignore usage of default ucf file, if present
      -u               Allow unexpanded blocks in output NGD design.
                       During partial design assembly flow, it gets used
                       along with -modular assemble switch to consider
                       unexpanded blocks as unimplemented modules.
                       Modular design flows:
         -modular initial
                       Modular design in initial budgeting mode
         -modular module -active <active_module_name>
                       Modular design in active module mode
                       Specifies the name of active module.
         -modular assemble -pimpath <pimpath> -use_pim <pim_module_name>
                       Modular design in assembly mode
            -pimpath <pimpath>
                       Specifies directory contains PIMs.
                       Specifies an instantiated module in a top level design.
                       -use_pim can be used multiple times to specify multiple
                       instantiated modules.
                       if -use_pim is missing, all subdirectories located in
                       <pimpath> directory, which contain a .ngo file with the
                       same subdirectory name, will be considered as valid
      -quiet           Only report Warning and Error messages
      -verbose         Reports all messages
NGDBUILD:  Translates and merges the various source files of a design into a
single "NGD" design database.
EXEWRAP detected a return code of '2' from program 'ngdbuild'
Done: failed with exit code: 0002.
程序不会错,买板的时候配的。基本每个程序都有这种错误。不知道是什么原因造成的。
   "__ngdbuild.rsp".
就是想请教一下这是由于什么问题造成的呢?
看看器件的配置对不对
