Linux内核同步机制的自旋锁原理及应用 03
二、自旋锁综合使用
    下面是一个使用的例子,你可以使用source insight查到它
    /* never called when PTRS_PER_PMD > 1 */
    void pgd_dtor(void *pgd, kmem_cache_t *cache, unsigned long unused)
    unsigned long flags; /* can be called from interrupt context */
    spin_lock_irqsave(&pgd_lock, flags);  枷锁
    pgd_list_del(pgd);
    spin_unlock_irqrestore(&pgd_lock, flags); 释放
    中断枷锁
    #define spin_lock_irqsave(lock, flags) _spin_lock_irqsave(lock, flags)
    分析
    unsigned long __lockfunc _spin_lock_irqsave(spinlock_t *lock)
    local_irq_save(flags); 将寄存器存入flags,并关中断
    preempt_disable();   抢占锁
    _raw_spin_lock_flags(lock, flags);  枷锁
    return flags;
    EXPORT_SYMBOL(_spin_lock_irqsave);
    继续
    /* For spinlocks etc */
    #define local_irq_save(x) __asm__ __volatile__("pushfl ; popl %0 ; cli":"=g" (x): /* no input */ :"memory")
    将标志寄存器的内容放在内存x中。请查看gcc汇编
    继续
    static inline void _raw_spin_lock_flags (spinlock_t *lock, unsigned long flags)
    #ifdef CONFIG_DEBUG_SPINLOCK
    if (unlikely(lock->magic != SPINLOCK_MAGIC)) {
    printk("eip: %p ", __builtin_return_address(0));
    BUG();
    #endif
    spin_lock_string_flags
    :"=m" (lock->slock) : "r" (flags) : "memory");
