linux设备模型之uart驱动架构分析 02
在前面提到。在对uart设备文件过程中。会将操作转换到对应的port上,这个port跟uart_driver是怎么关联起来的呢?这就是uart_add_ont_port()的主要工作了。
    顾名思义,这个函数是在uart_driver增加一个port.代码如下:
    int uart_add_one_port(struct uart_driver *drv, struct uart_port *port)
    struct uart_state *state;
    int ret = 0;
    struct device *tty_dev;
    BUG_ON(in_interrupt());
    if (port->line >= drv->nr)
    return -EINVAL;
    state = drv->state + port->line;
    mutex_lock(&port_mutex);
    mutex_lock(&state->mutex);
    if (state->port) {
    ret = -EINVAL;
    goto out;
    state->port = port;
    state->pm_state = -1;
    port->cons = drv->cons;
    port->info = state->info;
    * If this port is a console, then the spinlock is already
    * initialised.
    if (!(uart_console(port) && (port->cons->flags & CON_ENABLED))) {
    spin_lock_init(&port->lock);
    lockdep_set_class(&port->lock, &port_lock_key);
    uart_configure_port(drv, state, port);
    * Register the port whether it's detected or not.  This allows
    * setserial to be used to alter this ports parameters.
    tty_dev = tty_register_device(drv->tty_driver, port->line, port->dev);
    if (likely(!IS_ERR(tty_dev))) {
    device_can_wakeup(tty_dev) = 1;
    device_set_wakeup_enable(tty_dev, 0);
    } else
    printk(KERN_ERR "Cannot register tty device on line %d\n",
    port->line);
    * Ensure UPF_DEAD is not set.
    port->flags &= ~UPF_DEAD;
    out:
    mutex_unlock(&state->mutex);
    mutex_unlock(&port_mutex);
    return ret;
    首先这个函数不能在中断环境中使用。 Uart_port->line就是对uart设备文件序号。它对应的也就是uart_driver->state数组中的uart_port->line项。
    它主要初始化对应uart_driver->state项。接着调用uart_configure_port()进行port的自动配置。然后注册tty_device.如果用户空间运行了udev或者已经配置好了hotplug.就会在/dev下自动生成设备文件了。
    操作流程图如下所示:
    六:设备节点的open操作
    在用户空间执行open操作的时候,就会执行uart_ops->open. Uart_ops的定义如下:
    static const struct tty_operations uart_ops = {
    .open         = uart_open,
    .close        = uart_close,
    .write        = uart_write,
    .put_char = uart_put_char,
    .flush_chars  = uart_flush_chars,
    .write_room   = uart_write_room,
    .chars_in_buffer= uart_chars_in_buffer,
    .flush_buffer = uart_flush_buffer,
    .ioctl        = uart_ioctl,
    .throttle = uart_throttle,
    .unthrottle   = uart_unthrottle,
    .send_xchar   = uart_send_xchar,
    .set_termios  = uart_set_termios,
    .stop         = uart_stop,
    .start        = uart_start,
    .hangup       = uart_hangup,
    .break_ctl    = uart_break_ctl,
    .wait_until_sent= uart_wait_until_sent,
    #ifdef CONFIG_PROC_FS
    .read_proc    = uart_read_proc,
    #endif
    .tiocmget = uart_tiocmget,
    .tiocmset = uart_tiocmset,
    对应open的操作接口为uart_open.代码如下:
    static int uart_open(struct tty_struct *tty, struct file *filp)
    struct uart_driver *drv = (struct uart_driver *)tty->driver->driver_state;
    int retval, line = tty->index;
    BUG_ON(!kernel_locked());
    pr_debug("uart_open(%d) called\n", line);
    * tty->driver->num won't change, so we won't fail here with
    * tty->driver_data set to something non-NULL (and therefore
    * we won't get caught by uart_close())。
    retval = -ENODEV;
    if (line >= tty->driver->num)
    goto fail;
    * We take the semaphore inside uart_get to guarantee that we won't
    * be re-entered while allocating the info structure, or while we
    * request any IRQs that the driver may need.  This also has the nice
    * side-effect that it delays the action of uart_hangup, so we can
    * guarantee that info->tty will always contain something reasonable.
    state = uart_get(drv, line);
    if (IS_ERR(state)) {
    retval = PTR_ERR(state);
    goto fail;
    * Once we set tty->driver_data here, we are guaranteed that
    * uart_close() will decrement the driver module use count.
    * Any failures from here onwards should not touch the count.
    tty->driver_data = state;
    tty->low_latency = (state->port->flags & UPF_LOW_LATENCY) ? 1 : 0;
    tty->alt_speed = 0;
    state->info->tty = tty;
    * If the port is in the middle of closing, bail out now.
    if (tty_hung_up_p(filp)) {
    retval = -EAGAIN;
    state->count--;
    goto fail;
    * Make sure the device is in D0 state.
    if (state->count == 1)
    uart_change_pm(state, 0);
    * Start up the serial port.
    retval = uart_startup(state, 0);
    * If we succeeded, wait until the port is ready.
    if (retval == 0)
    retval = uart_block_til_ready(filp, state);
    * If this is the first open to succeed, adjust things to suit.
    if (retval == 0 && !(state->info->flags & UIF_NORMAL_ACTIVE)) {
    state->info->flags |= UIF_NORMAL_ACTIVE;
    uart_update_termios(state);
    fail:
    return retval;
