请看以下程序错在哪里?
信号应该在进程外。
[建议]
兄弟,做一个vga的显示控制器,错误的提示是什么呢?
请看以下程序错在哪里?
我的程序在MAXPLUS2中编译无法通过,请问问题出在哪里 library ieee; use ieee.std_logic_1164.all; USE ieee.std_logic_arith.all; entity seq_gen is port(clk_seq : in std_logic; rst_seq : in std_logic; lcd_hs_out : out std_logic;--行同步信号HS lcd_dataen : out std_logic; lcd_vs_out : out std_logic;--场同步信号VS pix_clk : out std_logic ); end seq_gen; architecture rtl_seq_gen of seq_gen is signal lcd_hb : std_logic;--行消隐信号HB signal lcd_hs : std_logic;--行同步信号HS signal lcd_vb : std_logic;--场消隐信号VB signal lcd_vs : std_logic;--场同步信号VS signal clken_vcount : std_logic; begin hcount: block signal hcountreg :std_logic_vector(9 downto 0); signal hz_temp : std_logic; signal lcd_hz : std_logic; begin process (clk_seq,lcd_hz) begin if (lcd_hz = '1') then hcountreg <= (others =>'0'); elsif clk_seq'event AND clk_seq = '1' then hcountreg <=hcountreg +1; end if; end process; lcd_hb <= '0' when hcountreg >=750 AND hcountreg < 800 --650/800(现在) 615/525(现在)替换 else '1'; lcd_hs <='0' when hcountreg >=520 AND hcountreg < 530 else '1'; hz_temp <= '1' when hcountreg = 800 else '0'; lcd_hz <=hz_temp or rst_seq; end block hcount; diff : block signal inputrega : std_logic; signal inputregb : std_logic; begin process(clk_seq) begin if clk_seq'event AND clk_seq='1' then inputregb <= inputrega; inputrega <= not lcd_hs; end if; end process; clken_vcount <= not inputregb and inputrega; end block diff; vcount : block signal vcountreg : std_logic_vector(9 downto 0); signal vz_temp : std_logic; signal lcd_vz : std_logic; begin process (clk_seq,lcd_vz) begin if(lcd_vz='1')then vcountreg <= (others => '0'); elsif clk_seq'event and clk_seq = '1' then if clken_vcount = '1' then vcountreg <= vcountreg +1; end if; end if; end process; lcd_vb <= '0' when vcountreg >=780 and vcountreg < 800 else '1'; lcd_vs <='0' when vcountreg >=520 and vcountreg < 525 else '1'; vz_temp <= '1' when vcountreg = 800 else '0'; lcd_vz <= vz_temp or rst_seq; end block vcount; pix_clk <=clk_seq; lcd_dataen <=lcd_hb and lcd_vb; lcd_hs_out <=lcd_hs; lcd_vs_out <=lcd_vs; end rtl_seq_gen;
