nios ide中编译程序遇到一个奇怪的问题,请大家给我一点意见。
很简单的一个hello world程序
但不知道为什么在ide中编译会说我错误,一直没有明白是什么地方错了,大家可以帮我看看,给我一点意见吗?
错误如下:
**** Incremental build of configuration Debug for project s60_sram_uart ****
make -s all
Compiling alt_exception_entry.S...
Compiling alt_exception_muldiv.S...
Compiling alt_exception_trap.S...
Compiling alt_execve.c...
Compiling alt_exit.c...
Compiling alt_fcntl.c...
Compiling alt_fd_lock.c...
Compiling alt_fd_unlock.c...
Compiling alt_find_dev.c...
Compiling alt_find_file.c...
Compiling alt_flash_dev.c...
Compiling alt_fork.c...
Compiling alt_fs_reg.c...
Compiling alt_fstat.c...
Compiling alt_get_fd.c...
Compiling alt_getpid.c...
Compiling alt_gettod.c...
Compiling alt_gmon.c...
Compiling alt_icache_flush.c...
Compiling alt_icache_flush_all.c...
Compiling alt_io_redirect.c...
Compiling alt_ioctl.c...
Compiling alt_irq_entry.S...
Compiling alt_irq_handler.c...
Compiling alt_irq_register.c...
Compiling alt_irq_vars.c...
Compiling alt_isatty.c...
Compiling alt_kill.c...
Compiling alt_link.c...
Compiling alt_load.c...
Compiling alt_lseek.c...
Compiling alt_main.c...
Compiling alt_malloc_lock.c...
Compiling alt_mcount.S...
Compiling alt_open.c...
Compiling alt_read.c...
Compiling alt_release_fd.c...
Compiling alt_remap_cached.c...
Compiling alt_remap_uncached.c...
Compiling alt_rename.c...
Compiling alt_sbrk.c...
Compiling alt_settod.c...
Compiling alt_software_exception.S...
Compiling alt_stat.c...
Creating alt_sys_init.c...
WARNING: Default charset GBK not supported, using ISO-8859-1 instead
Compiling alt_sys_init.c...
Compiling alt_tick.c...
Compiling alt_times.c...
Compiling alt_uncached_free.c...
Compiling alt_uncached_malloc.c...
Compiling alt_unlink.c...
Compiling alt_usleep.c...
Compiling alt_wait.c...
Compiling alt_write.c...
      2 [main] nios2-elf-gcc 21016 fork_copy: linked dll data/bss pass 0 failed, 0x5C6000..0x5C6264, done 0, windows pid 21020, Win32 error 487
1020405 [main] nios2-elf-gcc 21016 fork_copy: linked dll data/bss pass 0 failed, 0x5C6000..0x5C6264, done 0, windows pid 21140, Win32 error 487
3046347 [main] nios2-elf-gcc 21016 fork_copy: linked dll data/bss pass 0 failed, 0x5C6000..0x5C6264, done 0, windows pid 21148, Win32 error 487
7062076 [main] nios2-elf-gcc 21016 fork_copy: linked dll data/bss pass 0 failed, 0x5C6000..0x5C6264, done 0, windows pid 21172, Win32 error 487
nios2-elf-gcc: fork: Resource temporarily unavailable
make[1]: *** [obj/alt_write.o] Error 1
make: *** [system_project] Error 2
Build completed
为什么说我错呢?上面的文件alt_write.c等是系统带的,我没有改动过的。我用的是quartus5.0,nios IDE 5.0的。
大家给我一点意见吧,问题困扰我好几天了!
[此贴子已经被作者于2006-11-10 22:04:40编辑过]
你把环境重新安装一下吧,看起来好像是你的系统有问题,不行就重新安装系统。
在交流中前进,共同实现nios的应用。
