ccs如果编译c++程序,是否需要设置啥的呀,我现在编译失败
//h文件中class LZX_E2{     private:               void at24xx_start(void);            void edelay(unsigned int);            void at24xx_stop(void);            void at24xx_lo_clk(void);            void at24xx_ho_clk(void);            void at24xx_write_byte(unsigned int);            unsigned int at24xx_read_byte(void);     public:            void at24xx_write_datas(unsigned int,unsigned int,unsigned int *);            void at24xx_read_datas(unsigned int,unsigned int,unsigned int *);};//编译后提示"at24c02.h", line 4: [F001] syntax error at or near symbol 'LZX_E2' |
