- 女
时序仿真问题 | 我用QUARTUS6.0来时序仿真需要什么备置呀 我仿真怎么老是提示 Info: Running Quartus II Simulator Info: Version 6.0 Build 178 04/27/2006 SJ Full Version Info: Processing started: Sun Nov 19 11:33:03 2006 Info: Command: quartus_sim --read_settings_files=on --write_settings_files=off cdkzq -c cdkzq Error: Run Generate Functional Simulation Netlist (quartus_map cdkzq --generate_functional_sim_netlist) to generate functional simulation netlist for top level entity "cdkzq" before running the Simulator (quartus_sim) Error: Quartus II Simulator was unsuccessful. 1 error, 0 warnings Error: Processing ended: Sun Nov 19 11:33:03 2006 Error: Elapsed time: 00:00:01 请高手指点
