TMS320F2407扩展EEPROM问题请教,附相关程序
我用TMS320F2407的SPI外扩EEPROM,EEPROM的型号为ATMEL25640A,在通讯时收不到EEPROM返回的数据,请教做过相关项目的朋友,请指点一二.不胜感激!
附上读取EEPROM状态的程序.
#include "register.h"
/********SPI MEMORY INSTRUCTION SFR DEFINES****************/
#define WREN 0x0006
#define WRDI 0x0004
#define RDSR 0x0005
#define WRSR 0x0001
#define READ 0x0003
#define WRITE 0x0002
#define READY_TO_SEND      0x0000      //the SPI interface is ready to send
#define TRANSFER_COMPLETED 0x000C      //the read access is completed whithout error
#define BUSY               0x0005      //the SPI memory or the SPI interface is busy.
#define INSTRUCTION        0x0001      //the op_code has been transferred
#define SEND_COMPLETED     0x0006     //multi_bytes transmit completed
#define ADDRESS            0x0002     //address of Eprom is two bytes long
#define DATA               0x0004
#define FULL               0x000A
#define BUSY1              0x000B
/**************************the follow program are set the i/o port to
select|deselect EEPROM
/****************************IOPORT_INITIAL***************************/
void IoportInital()
 *MCRC=*MCRC&0x0000;   //config IOPE,IOPF as IOPORT
 *PFDATDIR=*PFDATDIR|0xFF00;  //portF as output
/*********************CHIP_SELECT*********************************/
void ChipSelect()
  *PFDATDIR=*PFDATDIR&0xFF00;  //pull down cs, port value=0
/*********************CHIP_DESELECT***************************/
void ChipDeselect()
  *PFDATDIR=*PFDATDIR|0x00FF; //pull high cs,port value=1
/*******Disable Interrupt*******/
void inline disable()
  asm(" setc INTM ");
/*******Enable Interrupt********/
void inline enable()
  asm(" clrc INTM ");
/*******System Initial************/
void initial()
  asm(" setc SXM ");
  asm(" clrc OVM ");
  asm(" clrc CNF ");
  *SCSR1=0x8322;  //CLKIN=20M,CLKOUT=20M*2=40M,Enable SPI Clock
  *WDCR=0x0E8;    //Disable WatchDog
  *IMR=0x0001;    //Enable Interrupt1(High PRI SPI interrupt)
  *IFR=0x0FFFF;   //Clear Interrupt Flag
  *WSGR=0x0000;   //Disable WaitState
/***********SPI_INT_ENABLE******
void spi_int_enable()
 // *SPICCR&=0x007F;  //enter Reset mode to configure SFR
  *SPICTL|=0x0001;
 // *SPICCR|=0x0080;  //quit Reset mode(corressponding to firtst line
/***********SPI_INT_DISABLE***************/
void spi_int_disable()
//  *SPICCR=*SPICCR&0x007F;  //enter Reset mode to configure SFR
  *SPICTL=*SPICTL&0xFFFE;
 // *SPICCR=*SPICCR|0x0080;  //quit Reset mode(corressponding to firtst line
/***********SPI Initial**************/
int spi_initial()
  *SPICCR=0x0007;      //8 char bits,data transfer at rising edge
                       //and receive at falling edge enter Reset mode
  *SPICTL=0x0007;      //enable spi int,enable transfer,work mode: master
 // *SPIBRR=0x0003;      //CLKOUT=40M,BAUDRATE=10M,according to formula
  *SPIBRR=0x0007;      //CLKOUT=40M,BAUDRATE=5M,according to formula
  *MCRB=0x003C;        //set IO as SPI function port
  *SPICCR|=0x0080;     //quit Reset mode,in accordance with the first line
  state=READY_TO_SEND;
/*********SPI_TRANSFER****************
*the function is the elementary function that handles the spi********
*interface in polling mode.it sends a byte and stores the received one**
int spi_transfer(int data)
  int flag,data_in=0x0000;
  flag=*SPISTS&0x0040;       //flag=SPI INT FLAG
  *SPITXBUF=(data<<8);
  while(flag=!0x0040){;}
  return (*SPIRXBUF>>8);
/************GetStatuRegister**************
**this function performs a RDSR access,it returns the access status code**
int GetStatusRegister(int *status)
  if(state==READY_TO_SEND)
     spi_int_disable();       //read the spi memory status register,disable interrupt first
     ChipSelect();            //pull down the CS
     spi_transfer(RDSR);      //transmit the op_code RDSR
     *status=spi_transfer(0xFF); //get the status value
     inner++;
     ChipDeselect();           // pull high the CS
     spi_int_enable();         //enable interrupt
     return TRANSFER_COMPLETED; //transfer completed
  else
     *status=1;
     return BUSY;
/*********************************main*************************************/
void main()
  int inner;
   disable();    //disable all interrupt
  initial();    //system initial
  spi_initial();  //spi initial
  IoportInital();  //ioport initial
  while(1)
     inner=GetStatusRegister(&jj);
我用这样的程序读取EEPROM的状态字,却收不到返回的信号,请问是哪里出了问题?
拜谢!
竟然没有回复,太残酷了......
