8、用HDL设计一个模块。完成有符号数除法,被除数为16-bit整数,除数为8-bit整数,输出8-bit商和8-bit余数,所有输入输出都是有符号数。
module div_16(clk,rst_n,a,b,c,d,div_out,p,div_c);
input clk;
input rst_n;
input
[15:0] a;
input
[7:0]
b;
output
[7:0]
c;
output
[7:0]
d;
output
[7:0]
div_out;
output
p;
output
[6:0] div_c;
wire
[15:0] div_a;
wire
[7:0]
div_b;
wire
p;
reg
[7:0]
div_c;
reg
[7:0]
div_d;
wire
[7:0]
div_out;
assign
div_a = (a[15] == 0) ? a : {a[15],~a[14:0]+1'b1};
assign
div_b = (b[7] == 0) ? b : {b[7],~b[6:0]+1'b1};
assign
p = a[15] ^ b[7];
always @ (posedge clk or negedge rst_n) begin
if(!rst_n) begin
div_c <= 8'b0;
div_d <= 8'b0;
div_d <= 8'b0;
end
else begin
div_c <= div_a[14:0] / {div_b[6:0]};
div_d <= div_a[14:0] % div_b[6:0];
end
end
//assign div_c = div_a[14:0] / div_b[6:0];
//assign div_d = div_a[14:0] % div_b[6:0];
assign div_out = {p,div_c[6:0]};
assign c = (div_out[7] == 0) ? div_out : {div_out[7],~div_out[6:0]+1'b1};
assign d = div_d;
if(!rst_n) begin
div_c <= 8'b0;
div_d <= 8'b0;
div_d <= 8'b0;
end
else begin
end
end
assign d = div_d;
endmodule
这样写的话基本就对了,还有一种写法是针对使用verilog-2001的,使用signed有符号定义,但modelsim仿真有点问题,我先贴出代码和仿真图先:
module div_8(clk,rst_n,a,b,c,d);
input clk;
input rst_n;
input signed [15:0] a;
input signed [7:0] b;
output signed [7:0] c;
output signed [7:0] d;
assign c = a / b;
assign d = a % b;
endmodule
你们估计看到了,若是使用这种写法的话,得到的模都是负值,后来我查了资料,模值是和第一个数的正负一样,就是和被除数是一样的。除非都是正值,不然还是有问题的。 |
