谁有适合28335的LED灯程序,最好是让从0~9输出的
不知道我的这个程序为啥不对,只能控制哪个灯亮,不可以输出数字
#include "DSP2833x_Device.h"
#include "DSP2833x_Examples.h"
//宏定义//
#define LED1_ON   GpioDataRegs.GPBSET.bit.GPIO58=1;
#define LED1_OFF  GpioDataRegs.GPBCLEAR.bit.GPIO58=1;
//变量定义//
unsigned char msg[10]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};
Uint16 number=0;
//函数声明//
void Spi_Init_Led(void);
void Spi_Init(void);
void Spi_Init_FIFO(void);
void Spi_mixt(Uint16 ch);
        EALLOW;
        GpioCtrlRegs.GPBPUD.bit.GPIO58=0;
        GpioCtrlRegs.GPBMUX2.bit.GPIO58=0;
        GpioCtrlRegs.GPBDIR.bit.GPIO58=1;
        EDIS;
        LED1_OFF;
void Sellect_bit(Uint16 i)
        switch(i)
                case 1:
                LED1_ON;
                break;
                default:
                break;
void delay(Uint32 t)
        Uint32 i=0;
        for(i=0;i<t;i++)
void Spi_Init(void)
        SpiaRegs.SPICCR.all=0x004F;
        SpiaRegs.SPICTL.all=0x0006;
        SpiaRegs.SPIBRR=0x007F;
        SpiaRegs.SPICCR.all=0x00DF;
        SpiaRegs.SPIPRI.bit.FREE=1;
        SpiaRegs.SPIFFTX.all=0xE040;
    SpiaRegs.SPIFFRX.all=0x204f;
    SpiaRegs.SPIFFCT.all=0x0;
        SpiaRegs.SPITXBUF=ch;
void main()
        InitSysCtrl();
        InitPieCtrl();
        InitPieVectTable();
        IER=0x0000;
        IFR=0x0000;
        DINT;
        Spi_Init_Led();
        Spi_Init();
        Spi_Init_FIFO();
        for(;;)
                        Sellect_bit(1);
                        Spi_mixt(msg[number]);
                        delay(30000);
                        number++;
                        if(number>9)
                        number=0;
