FLASH 没有烧写成功 是因为有些数据在RAM里吗
烧写完FLASH时  出现下面的警告:
“Initialized RAM Warning
Warning: Because this program contains
initialized RAM data it may run
successfully under Code Composer Studio
If your FLASH program requires
initialized data in RAM, you will need
to write FLASH code to nitialized RAM
FLASH 没有烧写成功  是因为有些数据在RAM里吗?如何修改呢? |
