#include "I2C.h"
* Function Name : I2C_Configuration
* Description :
* Input : None
* Output : None
* Return : None
* Attention
: None
void I2C_Configuration(void)
I2C_InitTypeDef I2C_InitStructure;
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO , ENABLE);
/* Configure I2C1 pins: PB10->SCL and PB11->SDA */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
GPIO_Init(GPIOB, &GPIO_InitStructure);
I2C_DeInit(I2C1);
I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
I2C_InitStructure.I2C_OwnAddress1 = 0x30;
I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
I2C_InitStructure.I2C_ClockSpeed = 100000;
I2C_Cmd(I2C1, ENABLE);
I2C_Init(I2C1, &I2C_InitStructure);
I2C_AcknowledgeConfig(I2C1, ENABLE);
* Function Name : I2C_delay
* Description :
* Input : None
* Output : None
* Return : None
* Attention
: None
static void I2C_delay(uint16_t cnt)
while(cnt--);
* Function Name : I2C_AcknowledgePolling
* Description :
* Input : I2C_TypeDef * , uint8_t
* Output : None
* Return : None
* Attention
: None
static void I2C_AcknowledgePolling(I2C_TypeDef *I2Cx,uint8_t I2C_Addr)
vu16 SR1_Tmp;
do
I2C_GenerateSTART(I2Cx, ENABLE);
SR1_Tmp = I2C_ReadRegister(I2Cx, I2C_Register_SR1);
//#ifdef AT24C01A
I2C_Send7bitAddress(I2Cx, I2C_Addr, I2C_Direction_Transmitter);
#else
I2C_Send7bitAddress(I2Cx, 0, I2C_Direction_Transmitter);
#endif
}while(!(I2C_ReadRegister(I2Cx, I2C_Register_SR1) & 0x0002));
I2C_ClearFlag(I2Cx, I2C_FLAG_AF);
I2C_GenerateSTOP(I2Cx, ENABLE);
* Function Name : I2C_Read
* Description :
* Input :
* Output :
* Return :
* Attention
: None
uint8_t I2C_Read(I2C_TypeDef *I2Cx,uint8_t I2C_Addr,uint8_t addr,uint8_t *buf,uint16_t num)
if(num==0)
return 1;
while(I2C_GetFlagStatus(I2Cx, I2C_FLAG_BUSY));
I2C_AcknowledgeConfig(I2Cx, ENABLE);
while(!I2C_CheckEvent(I2Cx, I2C_EVENT_MASTER_MODE_SELECT));
//#ifdef AT24C01A
while (!I2C_CheckEvent(I2Cx, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
I2C_SendData(I2Cx, addr);
while (!I2C_CheckEvent(I2Cx, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
I2C_Send7bitAddress(I2Cx, I2C_Addr, I2C_Direction_Receiver);
while(!I2C_CheckEvent(I2Cx, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
#else
I2C_Send7bitAddress(I2Cx, addr<<1, I2C_Direction_Receiver);
#endif
while (num)
if(num==1)
I2C_AcknowledgeConfig(I2Cx, DISABLE);
while(!I2C_CheckEvent(I2Cx, I2C_EVENT_MASTER_BYTE_RECEIVED)); /* EV7 */
*buf = I2C_ReceiveData(I2Cx);
buf++;
/* Decrement the read bytes counter */
num--;
return 0;
* Function Name : I2C_WriteOneByte
* Description :
* Input :
* Output : None
* Return :
* Attention
: None
uint8_t I2C_WriteOneByte(I2C_TypeDef *I2Cx,uint8_t I2C_Addr,uint8_t addr,uint8_t value)
//#ifdef AT24C01A
while(!I2C_CheckEvent(I2Cx, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
while(!I2C_CheckEvent(I2Cx, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
#else
I2C_Send7bitAddress(I2Cx, addr<<1, I2C_Direction_Transmitter);
#endif
I2C_SendData(I2Cx, value);
I2C_AcknowledgePolling(I2Cx,I2C_Addr);
I2C_delay(1000);
return 0;
* Description :
* Input :
* Output : None
* Return :
* Attention
: None
uint8_t I2C_Write(I2C_TypeDef *I2Cx,uint8_t I2C_Addr,uint8_t addr,uint8_t *buf,uint16_t num)
uint8_t err=0;
while(num--)
if(I2C_WriteOneByte(I2Cx, I2C_Addr,addr++,*buf++))
err++;
if(err)
return 1;
else
return 0;
