[求助] Flash Programmer Usage Problem
During running flash programmer:
#! /bin/sh # # This file was automatically generated by the Nios II IDE Flash Programmer. # # It will be overwritten when the flash programmer options change. #
cd C:/altera/kits/nios2_60/bin/eclipse/workspace/Project/DE2_Board_new/DE2_Board /system/software/count_binary_0/Debug
# Creating .flash file for the project $SOPC_KIT_NIOS2/bin/elf2flash --base=0x0040D800 --end=0x40d807 --reset=0x40c000 --input=count_binary_0.elf --output=asmi.flash --boot=$SOPC_KIT_NIOS2/components /altera_nios2/boot_loader_cfi.srec
# Programming flash with the project $SOPC_KIT_NIOS2/bin/nios2-flash-programmer --sidp=0x0040D838 --id=2273877087 --t imestamp=1165198630 --base=0x0040D800 asmi.flash Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x0040D838: No CFI table found at address 0x0040D80 0 verified Leaving target processor paused
# Creating .flash file for the project $SOPC_KIT_NIOS2/bin/elf2flash --base=0x00000000 --end=0x3fffff --reset=0x40c000 --input=count_binary_0.elf --output=cfi_flash_0.flash --boot=$SOPC_KIT_NIOS2/com ponents/altera_nios2/boot_loader_cfi.srec
# Programming flash with the project $SOPC_KIT_NIOS2/bin/nios2-flash-programmer --sidp=0x0040D838 --id=2273877087 --t imestamp=1165198630 --base=0x00000000 cfi_flash_0.flash Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x0040D838: verified Leaving target processor paused
What's wrong of my system ? (Some words output in console is in red) It seems the program terminated abnormally ...
Please help
it seams that you could not connect to the target. can you download codes in console mode. |
It is the same in console mode .... fail
you use the example of DE2, can success?? if failed, there is something wrong with your board. |
