28033的PLL时钟设置问题求教
28033的PLL时钟设置问题求教
在PLL初始化函数里有这么一段:
// If switching to 1/2
    if((divsel == 1)||(divsel == 2))
        EALLOW;
        SysCtrlRegs.PLLSTS.bit.DIVSEL = divsel;
        EDIS;
    // If switching to 1/1
    // * First go to 1/2 and let the power settle
    //   The time required will depend on the system, this is only an example
    // * Then switch to 1/1
    if(divsel == 3)
        EALLOW;
        SysCtrlRegs.PLLSTS.bit.DIVSEL = 2;
        DELAY_US(50L);
        SysCtrlRegs.PLLSTS.bit.DIVSEL = 3;
        EDIS;
可是在PLL设置表30里的描述却是:DIVSEL=0或1,DIVSEL=2,DIVSEL=3,怎么回事呀?
另外上面函数中 SysCtrlRegs.PLLSTS.bit.DIVSEL = 2;然后又SysCtrlRegs.PLLSTS.bit.DIVSEL = 3;我糊涂了,求教指导
