Multicycle Paths Constraints Instance (Vivado高效设计案例分享)
本节通过实例介绍一下多时钟周期路径(multicycle paths)的约束方法。       如图1中结构,主时钟fast_clk,时钟频率250MHz;时钟使能信号div_by_two,由主时钟2分频得到,作为寄存器的clock enable信号。
图1
       HDL代码如下所示:
module top(
    fast_clk,
    din_a,
    din_b,
    din_x,
    din_y,
    ab_out,
    xy_out
    ////////////// PORT /////////////////////////////
    input fast_clk;
    input [7:0] din_a;
    input [7:0] din_b;
    input [7:0] din_x;
    input [7:0] din_y;
    output reg [15:0] ab_out;
    output reg [15:0] xy_out;
    ////////////// ARCHITECTURE /////////////////////
    // Clock Enable
    reg div_by_two;
    always@(posedge fast_clk)
        div_by_two<=~div_by_two;
    // Input Registers
    reg [7:0] din_a_rg;
    reg [7:0] din_b_rg;
    reg [7:0] din_x_rg;
    reg [7:0] din_y_rg;
    always@(posedge fast_clk) begin
        if(div_by_two) begin
            din_a_rg <= din_a;
            din_b_rg <= din_b;
            din_x_rg <= din_x;
            din_y_rg <= din_y;
        end
    end
    // Multiplexer
    wire [7:0] mult_a;
    wire [7:0] mult_b;
    assign mult_a = div_by_two ? din_a : din_x;
    assign mult_b = div_by_two ? din_b : din_y;
    // Multiplier
    wire [15:0] mult_rlt;
    assign mult_rlt = mult_a * mult_b;
    // Ouptut Select
        if(div_by_two)
            xy_out <= mult_rlt;
        else
            ab_out <= mult_rlt;
    end
endmodule
       时序图如图2所示,其中din_*
  • --> din_*_reg
  • ,div_by_two_reg --> din_*_reg
  • 和div_by_two_reg --> **_out_reg
  • 路径都需要2个clock cycle,所有的多时钟周期路径如下表所示:
    Source Register
    Destination Register
    Set-Up Relationship
    Hold Relationship
    div_by_two_reg
    din_a_reg
  • ,din_b_reg
  • 2x (latch edge time)
    1x (latch edge time)
    div_by_two_reg
    ab_out_reg
  • ,xy_out_reg
    图2
           综合后,首先约束主时钟,如图3所示,此时时序还未收敛,时序报告如图4所示,可以发现关键路径都是需要多时钟周期约束的路径。
    图3
    图4
           然后约束多时钟周期路径,约束命令如下,如图5所示;此时时序也收敛,时序报告如图6所示。
    set_multicycle_path -setup -from[get_cells div_by_two_reg] -to [get_cells {ab_out_reg
  • din_a_IBUF
  • _inst din_b_IBUF
  • _inst din_x_IBUF
  • _inst din_y_IBUF
  • _inst xy_out_reg
  • }] 2
    set_multicycle_path -hold -from[get_cells div_by_two_reg] -to [get_cells {ab_out_reg
  • din_a_IBUF
  • _inst din_b_IBUF
  • _inst din_x_IBUF
  • _inst din_y_IBUF
  • _inst xy_out_reg
  • }] 1
    图5
    图6
  • 记录学习中的点点滴滴,让每一天过的更加有意义!
    共同努力,共同学习!
