关键字:GIC中断控制器 ARM
1 GIC : Generic Interrupt Controller
Distributor
–detecting, disabling, prioritizing, directing interrupts to CPU(s).
CPU interfaces
–asserting an interrupt indication to the CPU
Support max to 1020 interrupts
2 PPI,SPI and SGI
Peripheral interrupt
PPI : Private Peripheral Interrupt
specific to a single processor
SPI : Shared Peripheral Interrupt
Distributor can route to any of a specified combination of processors
Software-generated interrupt (SGI)
This is an interrupt generated by software writing to a GICD_SGIR register in the GIC. The system uses SGIs for interprocessor communication
ID0-ID15 are used for SGIs
ID16-ID31 are used for PPIs
ID32+ are used for SPIs
3 Models for handling interrupts in MP core
1-N model
Only one processor handles this interrupt. The system must implement a mechanism to determine which processor handles an interrupt that is programmed to target more than one processor.
N-N model
All processors receive the interrupt independently. When a processor acknowledges the interrupt, the interrupt pending state is cleared only for that processor. The interrupt remains pending for the other processors.
According to GIC document(p3-33)
software generated interrupts (SGIs) using the GIC N-N model
peripheral (hardware) interrupts PPI and SPI using the GIC 1-N model.
4 GIC interrupt handling sequence
1. The GIC determines the interrupts that are enabled.
2. For each pending interrupt, the GIC determines the targeted processor or processors.
3. For each CPU interface, the Distributor forwards the highest priority pending interrupt that targets that interface.
4. Each CPU interface determines whether to signal an interrupt request to its processor, and if required, does so.
5. The processor acknowledges the interrupt, and the GIC returns the interrupt ID and updates the interrupt state.
6. After processing the interrupt, the processor signals End of Interrupt (EOI) to the GIC.
