我又找了一下我大约是在2003年末用过的一个控件,叫“ImageOcx”,是个商用控件,非常不错,我用它把一个BMP文件(1.4M)压缩到了10K左右,感觉还行,所以推荐给大家! 用到的控件函数为: 函数原型: RESULT CVIFUNC IMAGEOCXLib__DImageOcxCompressImageOut (CAObjHandle objectHandle, ERRORINFO *errorInfo, const char *pFile1, const char *pFile2, float fTime, long lType, long *returnValue); 函数功能:压缩位图 函数说明: pFile1---------源文件 pFile2---------压缩文件 fTime----------倍率 lType----------图像类型 (1=bmp 2=tif) returnValue----返回值 函数原型: HRESULT CVIFUNC IMAGEOCXLib__DImageOcxDeCompressImageOut (CAObjHandle objectHandle, ERRORINFO *errorInfo, const char *pFile1, const char *pFile2, long *returnValue); 函数功能:还原位图 函数说明: pFile1---------压缩文件 pFile2---------解压文件 returnValue----返回值
界面为: 代码为: #include "ImageOcx.h" #include #include "toolbox.h" #include #include #include #include "图形压缩.h" static CAObjHandle objecthandle; static int bitmapID; static int panelHandle; int main (int argc, char *argv[]) { if (InitCVIRTE (0, argv, 0) == 0) return -1; /* out of memory */ if ((panelHandle = LoadPanel (0, "图形压缩.uir", PANEL)) < 0) return -1; GetObjHandleFromActiveXCtrl (panelHandle, PANEL_IMAGEOCX, &objecthandle); DisplayPanel (panelHandle); RunUserInterface (); DiscardPanel (panelHandle); if (bitmapID) { DiscardBitmap (bitmapID); } return 0; } int CVICALLBACK bmpCB (int panel, int control, int event, void *callbackData, int eventData1, int eventData2) { int sel; char path[MAX_PATHNAME_LEN]; long filesize; switch (event) { case EVENT_COMMIT: sel = FileSelectPopup ("", "*.bmp", "*.bmp", "打开位图", VAL_LOAD_BUTTON, 0, 1, 1, 1, path); if (sel > 0) { GetBitmapFromFile (path, &bitmapID); CanvasDrawBitmap (panelHandle, PANEL_CANVAS_ORGINAL, bitmapID, VAL_ENTIRE_OBJECT, VAL_ENTIRE_OBJECT); GetFileSize (path, &filesize); SetCtrlVal (panelHandle, PANEL_NUMERIC_BMP, filesize); } break; } return 0; } int CVICALLBACK jpegCB (int panel, int control, int event, void *callbackData, int eventData1, int eventData2) { int sel; char path[MAX_PATHNAME_LEN]; long filesize; switch (event) { case EVENT_COMMIT: if (bitmapID) { int ration; GetCtrlVal (panelHandle, PANEL_NUMERIC_RATION, &ration); sel = FileSelectPopup ("", "*.jpeg", "*.jpeg", "保存JPG图像", VAL_SAVE_BUTTON, 0, 1, 1, 1, path); if (sel > 0) { SaveBitmapToJPEGFile (bitmapID, path, JPEG_PROGRESSIVE, ration); DisplayImageFile (panelHandle, PANEL_PICTURE_CONVERT, path); GetFileSize (path, &filesize); SetCtrlVal (panelHandle, PANEL_NUMERIC_JPGE, filesize); } } break; } return 0; } int CVICALLBACK QuitCallback (int panel, int control, int event, void *callbackData, int eventData1, int eventData2) { switch (event) { case EVENT_COMMIT: QuitUserInterface (0); break; } return 0; } int CVICALLBACK compress (int panel, int control, int event, void *callbackData, int eventData1, int eventData2) { int sel; char path[MAX_PATHNAME_LEN]; long ret; int ration; switch (event) { case EVENT_COMMIT: sel = FileSelectPopup ("", "*.bmp", "*.bmp", "打开位图", VAL_OK_BUTTON, 0, 1, 1, 1, path); if (sel > 0) { GetCtrlVal (panelHandle, PANEL_NUMERIC_COMRAT, &ration); IMAGEOCXLib__DImageOcxCompressImageOut (objecthandle, NULL, &path[0], "sample1.cmp", ration, 1, &ret); DisplayImageFile (panelHandle, PANEL_PICTURE_ORGINAL, path); } break; } return 0; } int CVICALLBACK decompress (int panel, int control, int event, void *callbackData, int eventData1, int eventData2) { int sel; char path[MAX_PATHNAME_LEN]; long ret; switch (event) { case EVENT_COMMIT: sel = FileSelectPopup ("", "*.cmp", "*.cmp", "打开压缩位图", VAL_OK_BUTTON, 0, 1, 1, 1, path); if (sel > 0) { IMAGEOCXLib__DImageOcxDeCompressImageOut (objecthandle, NULL, &path[0], "3.bmp", &ret); DisplayImageFile (panelHandle, PANEL_PICTURE_COMMPRESS, "3.bmp"); } break; } return 0; } int CVICALLBACK size (int panel, int control, int event, void *callbackData, int eventData1, int eventData2) { int pheight; int width; int height; static int i = 0; switch (event) { case EVENT_COMMIT: if ( i == 0) { SetPanelAttribute (panelHandle, ATTR_HEIGHT, 700); SetCtrlAttribute (panelHandle, PANEL_CMD_SIZE, ATTR_LABEL_TEXT, "详细 <<"); i = 1; } else { SetPanelAttribute (panelHandle, ATTR_HEIGHT, 480); SetCtrlAttribute (panelHandle, PANEL_CMD_SIZE, ATTR_LABEL_TEXT, "详细 >>"); i = 0; } GetScreenSize (&height, &width); GetPanelAttribute (panelHandle, ATTR_HEIGHT, &pheight); SetPanelAttribute (panelHandle, ATTR_TOP, (int)((height-pheight)/2)+15); break; } return 0; }
