写了个模块 ,调试时总是读不出来值,请大家知道下,鉴别下哪里出错了. module counter( reset_n, clk_av, io, s_address, s_chipselect, s_read_n, s_write_n, s_writedata, s_readdata ); input reset_n; input clk_av; input io; input [15:0] s_address; input s_chipselect; input s_read_n; input s_write_n; input [15:0] s_writedata; output [15:0] s_readdata; reg [15:0] s_readdata; reg [15:0] counter_reg; reg [15:0] counter; reg [15:0] start_reg; reg [15:0] end_reg; always@(posedge clk_av or negedge reset_n) begin counter_reg <= counter; if(~reset_n) counter_reg <= 16'd0; else if(s_chipselect &(~s_write_n)&(s_address == 16'd0)) counter_reg <= s_writedata; end always@(posedge clk_av or negedge reset_n) begin if(~reset_n) start_reg <= 16'd0; else if(s_chipselect &(~s_write_n)&(s_address == 16'd1)) start_reg <= s_writedata; end always@(posedge clk_av or negedge reset_n) begin if(~reset_n) s_readdata <= 16'd0; else if(s_chipselect &(~s_read_n)) begin case(s_address) 16'd0: s_readdata <= counter_reg; //16'h00ff;// 16'd1: s_readdata <= start_reg; default: s_readdata <= 16'dz; endcase end end always@(io) begin if(start_reg==16'd1) counter <= counter + 1; end endmodule |
