S3C2410的WINCE BSP添加串口支持 02
else
#if USEVIRTUAL
EnterCriticalSection(&(pHWHead->RegCritSec));
v_pIOPregs->rGPHCON &= ~(0x3<<0 | 0x3<<2 | 0x3<<4 | 0x3<<6/* | 0x3<<12 | 0x3<<14*/); // clear uart 0 - rx, tx
v_pIOPregs->rGPHCON |= (0x2<<4 | 0x2<<6/* | 0x1<<12 | 0x0<<14*/);
v_pIOPregs->rGPHCON |= (0x2<<0 | 0x2<<2 );
v_pIOPregs->rGPHUP |= 0x03;
pHWHead->rDTRport = (volatile unsigned int *)&(v_pIOPregs->rGPHDAT);
pHWHead->rDSRport = (volatile unsigned int *)&(v_pIOPregs->rGPHDAT);
pHWHead->DtrPortNum = 0;
pHWHead->DsrPortNum = 1;
#else
volatile IOPreg *s2410IOP;
s2410IOP = (volatile IOPreg *)IOP_BASE; EnterCriticalSection(&(pHWHead->RegCritSec));
s2410IOP->rGPHCON &= ~(0x3<<0 | 0x3<<2 | 0x3<<4 | 0x3<<6 /*| 0x3<<12 | 0x3<<14*/); // clear uart 0 - rx, tx
s2410IOP->rGPHCON |= (0x2<<4 | 0x2<<6 /*| 0x1<<12 | 0x0<<14*/);
s2410IOP->rGPHCON |= (0x2<<0 | 0x2<<2 );
s2410IOP->rGPHUP |= 0x03;
pHWHead->rDTRport = (volatile unsigned int *)(IOP_BASE+0x74); //s2410IOP->rGPHDAT
pHWHead->rDSRport = (volatile unsigned int *)(IOP_BASE+0x74);
pHWHead->DsrPortNum =1;
#endif
LeaveCriticalSection(&(pHWHead->RegCritSec));
接着搜索:
SL_Init(
PVOID pHead, // @parm points to device head
PUCHAR pRegBase, // Pointer to 16550 register base
UINT8 RegStride, // Stride amongst the 16550 registers
EVENT_FUNC EventCallback, // This callback exists in MDD
PVOID pMddHead, // This is the first parm to callback
PLOOKUP_TBL pBaudTable // BaudRate Table
在PS2410_UART_INFO pHWHead = (PS2410_UART_INFO)pHead;这一句后面添加: PSER_INFO pHWHead1 = (PSER_INFO)pHead;
再搜索:
if ( pHWHead->UseIrDA )
pHWHead->bINT = BIT_UART2;
pHWHead->bTxINT = INTSUB_TXD2;
pHWHead->bRxINT = INTSUB_RXD2;
pHWHead->bErrINT = INTSUB_ERR2;
#if USEVIRTUAL
pHWHead->s2410SerReg = (S2410_UART_REG *)v_pUART2regs;
pRegBase = (PUCHAR)pHWHead->s2410SerReg;
#else
pRegBase = (PUCHAR)UART2_BASE;
pHWHead->s2410SerReg = (S2410_UART_REG *)pRegBase;
#endif
else
把这其中的代码修改为以下代码
} if(pHWHead1->dwIOBase == 0x50004000)
pHWHead->bINT = BIT_UART1;
pHWHead->bTxINT = INTSUB_TXD1;
pHWHead->bRxINT = INTSUB_RXD1;
pHWHead->bErrINT = INTSUB_ERR1;
#if USEVIRTUAL
pHWHead->s2410SerReg = (S2410_UART_REG *)v_pUART1regs;
#else
pRegBase = (PUCHAR)UART1_BASE;
#endif
