cordic算法verilog实现(复杂版)转载
module cordic (clk,rst_n,ena,phase_in,sin_out,cos_out,eps);parameter DATA_WIDTH=8; parameter PIPELINE=8; input     clk; input     rst_n; input     ena; input  [DATA_WIDTH-1:0]         phase_in; output [DATA_WIDTH-1:0]  sin_out;   output [DATA_WIDTH-1:0]  cos_out; output [DATA_WIDTH-1:0]  eps; reg    [DATA_WIDTH-1:0]  sin_out; reg    [DATA_WIDTH-1:0]  cos_out; reg    [DATA_WIDTH-1:0]  eps; reg    [DATA_WIDTH-1:0]  phase_in_reg; reg        [DATA_WIDTH-1:0]     x0,y0,z0; reg        [DATA_WIDTH-1:0]  x1,y1,z1; reg        [DATA_WIDTH-1:0]  x2,y2,z2; reg        [DATA_WIDTH-1:0]  x3,y3,z3; reg        [DATA_WIDTH-1:0]  x4,y4,z4; reg        [DATA_WIDTH-1:0]  x5,y5,z5; reg        [DATA_WIDTH-1:0]  x6,y6,z6; reg        [DATA_WIDTH-1:0]  x7,y7,z7; reg        [1:0]   quadrant[PIPELINE:0]; integer i; //get real quadrant and map to first_n quadrant always@(posedge clk or negedge rst_n) begin         if(!rst_n)                phase_in_reg<=8'b0000_0000;         else                if(ena)                        begin                                case(phase_in[7:6])                                       2'b00:phase_in_reg<=phase_in;                                       2'b01:phase_in_reg<=phase_in-8'h40;  //-pi/2                                       2'b10:phase_in_reg<=phase_in-8'h80;  //-pi                                       2'b11:phase_in_reg<=phase_in-8'hc0;  //-3pi/2                                       default:;                                 endcase                         end end always@(posedge clk or negedge rst_n) begin         if(!rst_n)                begin                        x0<=8'b0000_0000;                        y0<=8'b0000_0000;                        z0<=8'b0000_0000;                end          else                if(ena)                        begin                                x0<=8'h4D;  //define aggregate constant Xi=1/P=1/1.6467=0.60725 (Xi=2^7*P+8'h4D)                                y0<=8'h00;                                z0<=phase_in_reg;                        end end //level 1 always@(posedge clk or negedge rst_n) begin         if(!rst_n)                begin                        x1<=8'b0000_0000;                        y1<=8'b0000_0000;                        z1<=8'b0000_0000;                end          else                 if(ena)                        if(z0[7]==1'b0)                                begin                                       x1<=x0-y0;                                       y1<=y0+x0;                                       z1<=z0-8'h20;  //45deg                                end                else                        begin                                       x1<=x0+y0;                                       y1<=y0-x0;                                       z1<=z0+8'h20;  //45deg                 end      end //level 2 always@(posedge clk or negedge rst_n) begin         if(!rst_n)                begin                        x2<=8'b0000_0000;                        y2<=8'b0000_0000;                        z2<=8'b0000_0000;                end          else                 if(ena)                        if(z1[7]==1'b0)                                begin                                       x2<=x1-{y1[DATA_WIDTH-1],y1[DATA_WIDTH-1:1]};                                       y2<=y1+{x1[DATA_WIDTH-1],x1[DATA_WIDTH-1:1]};                                       z2<=z1-8'h12;  //26deg                                end                         else                                begin                                       x2<=x1+{y1[DATA_WIDTH-1],y1[DATA_WIDTH-1:1]};                                       y2<=y1-{x1[DATA_WIDTH-1],x1[DATA_WIDTH-1:1]};                                       z2<=z1+8'h12;                                end end //level 3   always@(posedge clk or negedge rst_n) begin         if(!rst_n)                begin                        x3<=8'b0000_0000;                        y3<=8'b0000_0000;                        z3<=8'b0000_0000;                 end          else                 if(ena)                        if(z2[7]==1'b0)                                begin                                       x3<=x2-{{2{y2[DATA_WIDTH-1]}},y2[DATA_WIDTH-1:2]};                                       y3<=y2+{{2{x2[DATA_WIDTH-1]}},x2[DATA_WIDTH-1:2]};                                       z3<=z2-8'h09;  //14deg                                end                         else                                begin                                       x3<=x2+{{2{y2[DATA_WIDTH-1]}},y2[DATA_WIDTH-1:2]};                                       y3<=y2-{{2{x2[DATA_WIDTH-1]}},x2[DATA_WIDTH-1:2]};                                       z3<=z2+8'h09;                                end end //level 4 always@(posedge clk or negedge rst_n) begin         if(!rst_n)                begin                        x4<=8'b0000_0000;                        y4<=8'b0000_0000;                        z4<=8'b0000_0000;                end          else                 if(ena)                        if(z3[7]==1'b0)                                begin                                       x4<=x3-{{3{y3[DATA_WIDTH-1]}},y3[DATA_WIDTH-1:3]};                                       y4<=y3+{{3{x3[DATA_WIDTH-1]}},x3[DATA_WIDTH-1:3]};                                       z4<=z3-8'h04;  //7deg                                end                         else                                begin                                       x4<=x3+{{3{y3[DATA_WIDTH-1]}},y3[DATA_WIDTH-1:3]};                                       y4<=y3-{{3{x3[DATA_WIDTH-1]}},x3[DATA_WIDTH-1:3]};                                       z4<=z3+8'h04;                                end end //level 5 always@(posedge clk or negedge rst_n) begin         if(!rst_n)                begin                        x5<=8'b0000_0000;                        y5<=8'b0000_0000;                        z5<=8'b0000_0000;                end          else                 if(ena)                        if(z4[7]==1'b0)                                begin                                       x5<=x4-{{4{y4[DATA_WIDTH-1]}},y4[DATA_WIDTH-1:4]};                                       y5<=y4+{{4{x4[DATA_WIDTH-1]}},x4[DATA_WIDTH-1:4]};                                       z5<=z4-8'h02;  //4deg                                end                         else                                begin                                       x5<=x4+{{4{y4[DATA_WIDTH-1]}},y4[DATA_WIDTH-1:4]};                                       y5<=y4-{{4{x4[DATA_WIDTH-1]}},x4[DATA_WIDTH-1:4]};                                       z5<=z4+8'h02;                                end end //level 6 always@(posedge clk or negedge rst_n) begin         if(!rst_n)                begin                        x6<=8'b0000_0000;                        y6<=8'b0000_0000;                        z6<=8'b0000_0000;                end          else                 if(ena)                        if(z5[7]==1'b0)                                begin                                       x6<=x5-{{5{y5[DATA_WIDTH-1]}},y5[DATA_WIDTH-1:5]};                                       y6<=y5+{{5{x5[DATA_WIDTH-1]}},x5[DATA_WIDTH-1:5]};         z6<=z5-8'h01;  //2deg                                end                         else                               begin                                       x6<=x5+{{5{y5[DATA_WIDTH-1]}},y5[DATA_WIDTH-1:5]};                                       y6<=y5-{{5{x5[DATA_WIDTH-1]}},x5[DATA_WIDTH-1:5]};                                       z6<=z5+8'h01;                                end end always@(posedge clk or negedge rst_n) begin         if(!rst_n)             for(i=0;i<=PIPELINE;i=i+1)                        quadrant[i]<=2'b00;         else                if(ena)                        begin                          for(i=0;i<PIPELINE;i=i+1)                            quadrant[i+1]<= quadrant[i];                            quadrant[0]<=phase_in[7:6];                        endendalways@(posedge clk or negedge rst_n) begin     if(!rst_n)         begin           sin_out<=8'b0000_0000;           cos_out<=8'b0000_0000;eps<=8'b0000_0000;         end     else        if(ena)           case(quadrant[7])             2'b00:begin                sin_out<=y6;                cos_out<=x6;                eps<=z6;             end              2'b01:begin                 sin_out<=x6;                 cos_out<=~(y6)+ 1'b1;                 eps<=z6;             end            2'b10:begin                 sin_out<=~(y6)+ 1'b1;                 cos_out<=~(x6)+ 1'b1;                 eps<=z6;            end            2'b11:begin                 sin_out<=~(x6)+ 1'b1;                 cos_out<=y6;                 eps<=z6;            end         encaseendendmodule
