#cd /babylinux/rootfs/sbin
#ls
chroot getty ifconfig losetup pivot_root reboot swapoff sysctl
fdisk halt init mkswap poweroff route swapon telnetd
查看到sbin下有上述链接
转到bin下
#cd /babylinux/rootfs/bin
重新做这些链接:
#ln -s busybox chroot
#ln -s busybox getty
#ln -s busybox ifconfig
然后把sbin下的链接删除,以节省空间
#rm -rf /babylinux/rootfs/sbin/*
再把原先inittab中所有的sbin改成bin
init.d下的文件:
rcS
请确保这个文件是可执行的,否则请改成可执行的:
#chmod u+x rcS
rcS的内容:
#! /bin/sh
mount -o remount,rw /
/bin/mount -a
>/etc/mtab
echo
echo
echo
echo
echo -en "\t\tWelcom to \\033[0;32mBabyLinux\\033][0;39m\n"
echo -en "\\033][0;36m\n"
echo
echo -en "++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++\t\t\n"
echo -en "+ This is a tiny linux system based on a floppy.It contains \t\t\n"
echo -en "+ more than 100 basic Linux commands and tools.The kernel of \t\t\n"
echo -en "+ this tiny system support all kinds of normal filesystems. \t\t\n"
echo -en "+ linux ext2,ext3,jfs,reiserfs and windows fat,vfat,ntfs][readonly]\t\t\n"
echo -en "+ is supported! So it is a powerful small system you can use it \t\t\n"
echo -en "+ as a linux and windows rescue disk.Beside this,the kernel also\t\t\n"
echo -en "+ contains the drivers of Reltek8139,NE2000,via-rhine ethernet\t\t\n"
echo -en "+ adpater. you can configure the IPaddress and netmask with tools\t\t\n"
echo -en "+ 'ifconfig' and config the default gateway with command 'route'. \t\t\n"
echo -en "+ Is there anything else? Haha,this is a telnet server build-in\t\t\n"
echo -en "+ you can type 'telnetd' to startd it and thus your friends can\t\t\n"
echo -en "+ logon to your system to help you solve the problem.\t\t\n"
echo -en "+ \\033[0;32mAll these great features are powered by BusyBox 1.0\\033][0;36m\t\t\n"
echo -en "+ This is a free system tool developed by GuCuiwen.\t\t\n"
echo -en "+ RUN YOUR OWN RISK of using it ! if you have any problem please\t\t\n"
echo -en "+ mailto : win2linux@163.com Enjoy!!\t\t\n"
echo -en "\\033][0;39m\n"
hostname BabyLinux
可以自己作相应的修改.
以上是babylinux根文件系统的所有内容,他的总大小应该在1M左右.
][root@gucuiwen baby]# du -hs
1.1M .
九,制作ramdisk映象文件
babylinux根文件系统所有东西都放在/babylinux/rootfs下,我们将利用ramdisk把这些内容做成ramdisk映象文件并压缩他.
以下主要是ramdisk的用法,看完以下内容,你应当学会ramdisk的使用.
[root@gucuiwen babylinux]# dd if=/dev/zero of=/dev/ram1
dd: 正在写入 ‘/dev/ram1’: 设备上没有空间
读入了 8193+0 个块
输出了 8192+0 个块
zero是一个特殊的设备,表示全部为0的字符块.上面这条命令的意思是把系统的第一个ramdisk用全部为0的数据填充,因为ramdisk默认大小为4M,因此当读满8192个块(每块512字节)后,显示'设备上没空间'.这很正常,/dev/ram1已经被填充满了.
如果指定块的大小:
[root@gucuiwen babylinux]# dd if=/dev/zero of=/dev/ram1 bs=1M count=4
读入了 4+0 个块
输出了 4+0 个块
不会有错误提示,这里演示了dd的一般用法,接下来还要频繁用到dd命令.
在/dev下有很多ramdisk设备,ram1,ram2,ram3....
一般用第一个就可以了.
填充后,ram1就有可空间,可以在这个空间上创见一个文件系统:
[root@gucuiwen babylinux]# mkfs.ext2 -m0 /dev/ram1
mke2fs 1.32 (09-Nov-2002)
Filesystem label=
OS type: Linux
Block size=1024 (log=0)
Fragment size=1024 (log=0)
1024 inodes, 4096 blocks
0 blocks (0.00%) reserved for the super user
First data block=1
1 block group
8192 blocks per group, 8192 fragments per group
1024 inodes per group
Writing inode tables: done
Writing superblocks and filesystem accounting information: done
This filesystem will be automatically checked every 37 mounts or
180 days, whichever comes first. Use tune2fs -c or -i to override.
将ram1挂装到文件系统中:
先建立一个挂装点:
#mkdir /mnt/ram
挂上ram1:
#mount /dev/ram1 /mnt/ram
将先前做好的babylinux根文件系统拷贝到ram1上.
#cp -R /babylinux/rootfs/* /mnt/ram
做完以上几步,你应就白了ramdisk设备的含义,他是和hda1,hdb1,一样的块设备,用mount挂到文件系统下后就可以访问,往里放东西,但是所有的东西在内存上.关机将丢失所有东西.
拷贝好babylinux根文件系统后卸载ram1:
#umount /dev/ram1
这时,虽然不能通过/mnt/ram这个挂装点访问ram1中的内容了,但是他却切切实实得在内存中存在.
再用dd把这个ram1以映象方式取出来:
[root@gucuiwen babylinux]# dd if=/dev/ram1 of=/babylinux/ramdisk.img
读入了 8192+0 个块
输出了 8192+0 个块
验证一下取出来的内容:
[root@gucuiwen babylinux]# file ramdisk.img
ramdisk.img: Linux rev 1.0 ext2 filesystem data
他是一个ext2 文件系统,类似一个ISO光盘映象文件.
因次,我们可以用loop设备来把他重新挂装到文件系统里:
[root@gucuiwen babylinux]# mount -o loop ramdisk.img /mnt/ram/
为了方便,我仍旧把他挂在/mnt/ram下,因此,在先前一定要把/dev/ram1 umount掉
查看/mnt/ram下的内容,他应该和/babylinux/rootfs下的一模一样,否则就是出错了:
[root@gucuiwen babylinux]# ls /mnt/ram
bin dev etc home lost+found mnt proc root sbin tmp usr var
这样,我们就得到了一个ramdisk根文件系统映象:ramdisk.img
把他umount掉:
#umount /mnt/ram
如果是第一次接触ramdisk,你可能对上述的内容很迷惑,如果这样,请反复阅读和理解上面的内容,自己多动手做几次试验,就可以理解.
压缩ramdisk.img印象文件:
[root@gucuiwen babylinux]# gzip -v9 ramdisk.img
ramdisk.img: 87.9% -- replaced with ramdisk.img.gz
查看压缩后的大小:
[root@gucuiwen babylinux]# ls -lh ramdisk.img.gz
-rw-r--r-- 1 root root 495K 11月 30 11:32 ramdisk.img.gz
我得到的压缩ramdisk映象文件安是495K. 加上内核的845K,是1340K
符合公式:
内核大小+文件系统压缩印象文件+50K <= 1440K
如果你做出来的kernel和ramdisk.img.gz太大了,请重新制作kernel或ramdisk.img.gz,在其中做一些取舍,如果你的 kernel和ramdisk.img.gz太小了,那么可以再往里面添加一些内容,使你的babylinux功能更强.
十,内核与busybox的整合
准备一张完好的空白软盘
创建一个比内核大小略大的文件系统:
比如内核大小是845K,那么我我创见一个920K的文件系统:
#mkfs.ext2 -m0 /dev/fd0 920
如果空间允许,还可以再大一些,但是必需保证
1440K-文件系统大小>=ramdisk.img.gz的大小.
挂上软盘
#mount /dev/fd0
将内核拷贝到软盘:
#cp /babylinux/bzImage /mnt/floppy/
将lilo引导文件安boot.b 拷贝到软盘
#cp /boot/boot.b /mnt/floppy
新建一个lilo.conf 配置文件:
prompt
timeout=60
default=linux
boot=/dev/fd0
map=/mnt/floppy/map
install=/mnt/floppy/boot.b
linear
image=/mnt/floppy/bzImage
label=linux
read-only
vga=788
root=/dev/fd0
append="load_ramdisk=1 ramdisk_start=940"
vga=788表示让内核支持字符界面的高分辨率显示,你可以改成vga=ask,这样可以在启动的时候选择分辨率.
红色一行是关键,load_ramdisk=1告诉内核在启动的时候转载压缩的ramdisk印象文件,
ramdisk_start=940 告诉内核从软盘的第940K的地方去寻找并装载压缩的ramdisk印象文件.
关于ramdisk的用法和更多参数请查看linux0内核文档/usr/src/linux/Documents/ramdisk.txt
接下来再用dd命令把ramdisk.img.gz装到软盘上.
#dd if=/babylinux/ramdisk.img.gz of=/dev/fd0 bs=1k seek=940
这里的seek=940 表示把ramdisk.img.gz装到软盘的第940K开始的地方.
详细内容请看dd的联机文档 man dd
为什么要从940k开始呢?
因为刚才作了一个920K的文件系统.我把他装在文件系统20K以后的地方.
当然,如果你的空间十分紧张,连这20K都不舍得浪费,那么可以这样:
#dd if=/babylinux/ramdisk.img.gz of=/dev/fd0 bs=1k seek=921
当然,别忘记修改lilo.conf文件. ramdisk_start=921
接下来装lilo引导程序就大功告成了.
#lilo -C lilo.conf
如果你的磁盘上还有一点点空余空间,那么可以把lilo.conf也拷贝上去,以备将来使用.
#cp lilo.conf /mnt/floppy
#umount /dev/fd0
整个工程已经完成了,你可以重新启动机器,设置电脑从软盘启动.看看有没有成功.
十一,安装测试和内容调整
如果在整合内核和ramdisk映象过程中,出现磁盘空间不够的情况,请重新编译内核和busybox
可以根据实际需要,调整内核和busybox,比如你要内核支持很多东西,但是只需要一个支持50个命令的busybox,那么可以自己做相应调整.
十二,babylinux中的BUG
有些命令的输出结果会有偏差,比如用 busybox的df 看磁盘使用情况,和实际的不一样.
十三,接下来要做的事情
做一个基于64M U盘的linux小系统.
计划支持如下特征:
a.软盘babylinux的所有功能
b.图形界面的支持.
c.一个轻量级的窗口管理器(window maker)
d.网络的支持,
e.至少一个图形web浏览器,可以上网.
f.一个音乐播放器和一个视频播放器.
g.支持中文的显示和输入.
h.可以修改配置并保存数据 |
