详解PIC12LC508A芯片解密技术
详解PIC12LC508A芯片解密技术
[url=]龙芯世纪科技[/url]长期提供高效、高可靠性、低成本、短周期的解密服务。针对AT88SC1003芯片解密,龙芯世纪科技早先就曾针对客户的解密需求进行过方案开发,而近期在该[url=]芯片解密[/url]中的技术突破将为更多客户带来实实在在的利益。
  有PIC12LC508A[url=]芯片解密[/url]需求者欢迎与龙芯世纪科技联系详细的解密合作详情,这里,我们仅提供对PIC12LC508A芯片的主要特征介绍,供大家参考借鉴。
  High-Performance RISC CPU:
  ? Only 33 single word instructions to learn
  ? All instructions are single cycle (1 ms) except for
  program branches which are two-cycle
  ? 12-bit wide instructions
  ? 8-bit wide data path
  ? Seven special function hardware registers
  ? Two-level deep hardware stack
  ? Direct, indirect and relative addressing modes for
  data and instructions
  ? Internal 4 MHz RC oscillator with programmable
  calibration
  ? In-circuit serial programming
  Peripheral Features:
  ? 8-bit real time clock/counter (TMR0) with 8-bit
  programmable prescaler
  ? Power-On Reset (POR)
  ? Device Reset Timer (DRT)
  ? Watchdog Timer (WDT) with its own on-chip RC
  oscillator for reliable operation
  ? Programmable code-protection
  ? 1,000,000 erase/write cycle EEPROM data
  memory
  ? EEPROM data retention > 40 years
  ? Power saving SLEEP mode
  ? Wake-up from SLEEP on pin change
  ? Internal weak pull-ups on I/O pins
  ? Internal pull-up on MCLR pin
  ? Selectable oscillator options:
  - INTRC: Internal 4 MHz RC oscillator
  - EXTRC: External low-cost RC oscillator
  - XT: Standard crystal/resonator
  - LP: Power saving, low frequency crystal
  CMOS Technology:
  ? Low power, high speed CMOS EPROM/ROM
  technology
  ? Fully static design
  ? Wide operating voltage range
  ? Wide temperature range:
  - Commercial: 0°C to +70°C
  - Industrial: -40°C to +85°C
  - Extended: -40°C to +125°C
  ? Low power consumption
  - < 2 mA @ 5V, 4 MHz
  - 15 mA typical @ 3V, 32 KHz
  - < 1 mA typical standby current
