Renesas RL78G13 16位MCU开发方案
- 来自
- 燕山大学
Renesas公司的RL78/G13采用新型RL78 CPU内核,工作频率高达32MHz,工作电压1.6V-5.5V,适合各种类型的消费类电子和工业应用,如工业自动化,家庭自动化,电动工具,白色家电,计量,医疗,照明和马达控制。本文介绍了RL78G13主要特性,方框图,RL78 RDK评估板目标应用和主要特性,方框图,电路图,材料清单和PCB元件布局图。
The RL78/G13 are built around the new RL78 CPU core, which is based on the 78K0R CPU core, and can be applied to all sorts of consumer and industrial applications.
The RL78 Family of microcontrollers (MCUs) combines advanced low power technology, outstanding performance, and the broadest line-up in its class for the most demanding 8- and 16-bit embedded applications.
The RL78 MCUs‘ innovative “Snooze“ mode achieves ultra-low power by allowing ADC operation and serial communication, all while the CPU is turned off. This makes the RL78 MCUs best in class for low power applications.
16-Bit Single-Chip Microcontrollers
RL78G13主要特性:
RL78G13主要应用:
Industrial Automation
n RL78 offers an extensive range of small packages
n RL78 has standard and extended temperature range devices from -40℃ to +85℃
n Renesas is renowned for highquality, long-life MCUs
Home Automation
n For long battery life, RL78 offers class-leading low power, including the unique Snooze mode
n Battery operation down to 1.6V
Consumer
n RL78 MCUs offer a full calendar function
n RL78 has an integrated temperature sensor
n Future families of RL78 will have display drive and USB drive integrated
Power Tools
n RL78 is available in multiple packages and scalable for the platform design approach
n Renesas MCUs integrate extensive safety features, adding to the quality and safety of the device
White Goods
n RL78 offers integrated safety compliance for white goods (IEC 60730)
n RL78 offers high temperature support
n RL78’s integrated peripherals make it the ideal choice for cost sensitive white goods
Medical
n When a small package MCU with long product life is required, RL78 is your first choice
n Renesas has provided solutions for major medical manufacturers and is part of the Continua Alliance
Lighting
n RL78/I1A offers dedicated DALI and Power Factor control
n RL78/IA integrates high resolution PWM timers
n RL78’s free Windows-based Applilet software makes it easy for designers to turn around a lighting design with little design experience
Metering
n RL78’s low power modes make the MCU ideal to meet industry power consumption
requirements
n RL78 is analog rich, ideal for smart metering applications
n Renesas has decades of experience providing high-quality and long-product life MCUs for metering applications
Motor Control
n RL78/G14 family is ideal for motor control applications with integrated MC timers
n RL78’s on-chip oscillators with 1% accuracy provide an integrated low cost solution for timing critical applications
图1。RL78系列20引脚方框图
图2。RL78系列100引脚方框图
RL78 RDK评估板
This RDK is an evaluation and demonstration tool for Renesas RL78 low-power microcontrollers. The goal is to provide the user with a powerful debug and demonstration platform targeted at common applications. A set of human/machine interfaces are tightly integrated with the features of the RL78 and the software demonstration programs providing the user with an accessible platform to rapidly evaluate and customize.
RL78 RDK评估板目标应用和主要特性:
Audio
• Stereo audio driver connected to the PWM interface
• Amplified on-board speaker and external audio jack.
• On-board microphone to demonstrate sampling, FFT/FPU capabilities
• Volume Control Potentiometer
User Interface
• Graphical LCD
• User pushbutton switches and a reset switch.
• On-board LEDs
Communications
• RS-232 Interface
• I2C, SPI with Debug through the Beagle connector from Total Phase
• Application Header to support several external WiFi modules.
• PMOD connections to support a variety of generic PMOD devices (WiFi, Bluetooth, RF, and much more).
Memory Storage
• Micro SD card slot
• 512KB Serial EEPROM
• 512KB On-chip Flash Memory
Digital Sensors
• 3 – Axis Accelerometer
• Temperature Sensor
• Ambient Light Sensor
Power Control
• FET Circuit for DC output
• TRIAC Circuit for AC output
User Code and Application Debugging
• On-board debugger for high-quality source code debugging (TK interface)
• User circuit breadboard area
图3。RL78 RDK评估板外形图
图4。RL78 RDK评估板方框图
图5。RL78 RDK评估板电路图(1)
图6。RL78 RDK评估板电路图(2)
图7。RL78 RDK评估板电路图(3)
图8。RL78 RDK评估板电路图(4)
图9。RL78 RDK评估板电路图(5)
图10。RL78 RDK评估板电路图(6)
图11。RL78 RDK评估板电路图(7)
图12。RL78 RDK评估板元件布局图(1)
图13。RL78 RDK评估板元件布局图(2)
RL78 RDK评估板材料清单见:
RL78 RDK评估板材料清单.rar (20.15 KB, 下载次数: 5) 2012-6-4 15:06:09 上传
下载次数: 5
下载积分: 积分 -1
详情请见:
YRDKRL78G13_SCH_2[1].pdf (150.74 KB, 下载次数: 10) 和
YRDKRL78G13_User_Manual[1].pdf (2.46 MB, 下载次数: 14) |
