- 来自
- 中国
原文链接:http://blog.csdn.net/ywhfdl/article/details/7574624
熬夜到了1点了,终于写出了1602的时钟计数器代码。为什么是时钟计数器呢?
因为我还没来得及做校准时间,所以只能称之为时钟计数器,不能成为电子钟。
网上很少用人公开这一类代码,一搜FPGA 1602,都是写一个静态的显示,在实际应用中,是没有用的,因此这个简单的例子,给大家抛砖引玉了!
上代码: Qii 9.0编译过,21EDA 开发板测试OK
module LCD
rst,
key1,
clk,
rw,
rs,
en,
data
input clk,rst,key1;
output rs,en,rw;
output [7:0] data;
reg rs,en_sel;
reg [7:0] data;
reg [7:0] shi,fen,miao;
reg [31:0]count,count1; //LCD CLK 分频计数器
reg lcd_clk;
reg [7:0] one_1,one_2,one_3,one_4,one_5,one_6,one_7,one_8,one_9,one_10,one_11,one_12,one_13,one_14,one_15,one_16;
reg [7:0] two_1,two_2,two_3,two_4,two_5,two_6,two_7,two_8,two_9,two_10,two_11,two_12,two_13,two_14,two_15,two_16;
reg [7:0] next,xianshi,two;
parameter state0 =8'h00, //设置8位格式,2行,5*7 8'h38;
state1 =8'h01, //整体显示,关光标,不闪烁 8'h0C 闪烁 8'h0e
state2 =8'h02, //设定输入方式,增量不移位 8'h06
state3 =8'h03, //清除显示 8'h01
state4 =8'h04, //显示第一行的指令 80H
state5 =8'h05, //显示第二行的指令 80H+40H
scan =8'h06,
nul =8'h07;
parameter data0 =8'h10, //2行,共32个数据
data1 =8'h11,
data2 =8'h12,
data3 =8'h13,
data4 =8'h14,
data5 =8'h15,
data6 =8'h16,
data7 =8'h17,
data8 =8'h18,
data9 =8'h19,
data10 =8'h20,
data11 =8'h21,
data12 =8'h22,
data13 =8'h23,
data14 =8'h24,
data15 =8'h25,
data16 =8'h26,
data17 =8'h27,
data18 =8'h28,
data19 =8'h29,
data20 =8'h30,
data21 =8'h31,
data22 =8'h32,
data23 =8'h33,
data24 =8'h34,
data25 =8'h35,
data26 =8'h36,
data27 =8'h37,
data28 =8'h38,
data29 =8'h39,
data30 =8'h40,
data31 =8'h41;
initial //初始值
begin
//第一行显示 TEL:13868160569
one_1<="T"; one_2<="E"; one_3<="L"; one_4<=":"; one_5<="1"; one_6<="3"; one_7<="8"; one_8<="6";
one_9<="8";one_10<="1";one_11<="6";one_12<="0";one_13<="5";one_14<="6";one_15<="9";one_16<=" ";
//第二行显示 Clock:00-00-00
two_1<="C"; two_2<="l"; two_3<="o"; two_4<="c"; two_5<="k"; two_6<=":"; two_7<=" "; two_8<=" ";
two_9<="-";two_10<=" ";two_11<=" ";two_12<="-";two_13<=" ";two_14<=" ";two_15<=" ";two_16<=" ";
shi<=0;fen<=0;miao<=0;
end
always @(posedge clk ) //获得LCD时钟
begin
count<=count+1;
if(count==250000)
begin
count<=0;
lcd_clk<=~lcd_clk;
end
end
always @(posedge clk or negedge rst ) //时钟计数器
begin
if(!rst)
begin
count1<=0;
end
else
begin
en_sel<=1;
two_7<= (shi/10)+8'b00110000;
two_8<= (shi%10)+8'b00110000;
two_10<=(fen/10)+8'b00110000;
two_11<=(fen%10)+8'b00110000;
two_13<=(miao/10)+8'b00110000;
two_14<=(miao%10)+8'b00110000;
count1<=count1+1'b1;
if(count1==49999999) // 时钟计数
begin
count1<=0;
miao<=miao+1;
if(miao==59)
begin
miao<=0;
fen<=fen+1;
if(fen==59)
begin
fen<=0;
shi<=shi+1;
if(shi==23)
begin
shi<=0;
end
end
end
end
end
end
always @(posedge lcd_clk )
begin
case(next)
state0 :
begin rs<=0; data<=8'h38; next<=state1; end //配置液晶
state1 :
begin rs<=0; data<=8'h0e; next<=state2; end
state2 :
begin rs<=0; data<=8'h06; next<=state3; end
state3 :
begin rs<=0; data<=8'h01; next<=state4; end
state4 :
begin rs<=0; data<=8'h80; next<=data0; end //显示第一行
data0 :
begin rs<=1; data<=one_1; next<=data1 ; end
data1 :
begin rs<=1; data<=one_2; next<=data2 ; end
data2 :
begin rs<=1; data<=one_3; next<=data3 ; end
data3 :
begin rs<=1; data<=one_4; next<=data4 ; end
data4 :
begin rs<=1; data<=one_5; next<=data5 ; end
data5 :
begin rs<=1; data<=one_6; next<=data6 ; end
data6 :
begin rs<=1; data<=one_7; next<=data7 ; end
data7 :
begin rs<=1; data<=one_8; next<=data8 ; end
data8 :
begin rs<=1; data<=one_9; next<=data9 ; end
data9 :
begin rs<=1; data<=one_10; next<=data10 ; end
data10 :
begin rs<=1; data<=one_11; next<=data11 ; end
data11 :
begin rs<=1; data<=one_12; next<=data12 ; end
data12 :
begin rs<=1; data<=one_13; next<=data13 ; end
data13 :
begin rs<=1; data<=one_14; next<=data14 ; end
data14 :
begin rs<=1; data<=one_15; next<=data15 ; end
data15 :
begin rs<=1; data<=one_16; next<=state5 ; end
state5:
begin rs<=0;data<=8'hC0; next<=data16; end //显示第二行
data16 :
begin rs<=1; data<=two_1; next<=data17 ; end
data17 :
begin rs<=1; data<=two_2; next<=data18 ; end
data18 :
begin rs<=1; data<=two_3; next<=data19 ; end
data19 :
begin rs<=1; data<=two_4; next<=data20 ; end
data20 :
begin rs<=1; data<=two_5; next<=data21 ; end
data21 :
begin rs<=1; data<=two_6; next<=data22 ; end
data22 :
begin rs<=1; data<=two_7; next<=data23 ; end
data23 :
begin rs<=1; data<=two_8; next<=data24 ; end
data24 :
begin rs<=1; data<=two_9; next<=data25 ; end
data25 :
begin rs<=1; data<=two_10; next<=data26 ; end
data26 :
begin rs<=1; data<=two_11; next<=data27 ; end
data27 :
begin rs<=1; data<=two_12; next<=data28 ; end
data28 :
begin rs<=1; data<=two_13; next<=data29 ; end
data29 :
begin rs<=1; data<=two_14; next<=data30 ; end
data30 :
begin rs<=1; data<=two_15; next<=data31 ; end
data31 :
begin rs<=1; data<=two_16; next<=scan ; end
scan : //交替更新第一行和第二行数据
begin
next<=state4;
end
default: next<=state0;
endcase
end
assign en=lcd_clk && en_sel;
assign rw=0;
endmodule |
