LV小技巧:使程序中的Matlab或HiQ脚本在LV生成的可执行文件中照样运行
Create a subdirectory called "script" in the directory where the executable resides. If you are using the MATLAB script node, copy matscript.dll from LabVIEW\Resource\Script into this directory. If using the HiQ script node, copy hiqscript.dll in the same fashion.
You can perform these steps as part of the application build. Add these DLLs as support files and specify a custom destination for them using the "Custom Destinations" button under the "Source Files" tab.
If you do not perform this step, you will receive error 1053, failed to load script support dll.
希望能够在不久的将来有次合作的机会  群:18994538 QQ: 364304745  个人主页:http://ldmcu.shangwusou.com/
呵呵!好东西啊
呵呵
好东西需要大家的支持呀
只可惜是个英文的,有兴趣的朋友可以把他给翻译成中文,方便大家参考呀
