- 来自
- 燕山大学
Embest NXP LPC1114 入门开发方案
NXP公司的LPC1111/12/13/14是低成本32位ARM
Cortex-M0微控制器(MCU),多达32kB闪存和8kB SRAM,设计用于8/16位MCU应用,和现有的8/16位MCU相比,具有高性能,低功耗,简单指令集和存储器寻址和降低代码大小,CPU工作频率高达50MHz,主要用在电子仪表,照明,工业网络,告警系统和白色家电.本文介绍了LPC1111/12/13/14主要特性,方框图以及Embest NXP LPC1114 入门开发套件主要特性和电路图.
LPC1111/12/13/14: 32-bit ARM Cortex-M0 microcontroller; up to 32 kB flash and 8 kB SRAM
The LPC1111/12/13/14 are a ARM Cortex-M0 based, low-cost 32-bit MCU family, designed for 8/16-bit microcontroller applications, offering performance, low power, simple instruction set and memory addressing together with reduced code size compared to existing 8/16-bit architectures.
The LPC1111/12/13/14 operate at CPU frequencies of up to 50 MHz.
The peripheral complement of the LPC1111/12/13/14 includes up to 32 kB of flash memory, up to 8 kB of data memory, one Fast-mode Plus I2C-bus interface, one RS-485/EIA-485 UART, up to two SPI interfaces with SSP features, four general purpose timers, a 10-bit ADC, and up to 42 general purpose I/O pins.
LPC1111/12/13/14主要特性:
􀂄 ARM Cortex-M0 processor, running at frequencies of up to 50 MHz.
􀂄 ARM Cortex-M0 built-in Nested Vectored Interrupt Controller (NVIC).
􀂄 32 kB (LPC1114), 24 kB (LPC1113), 16 kB (LPC1112), or 8 kB (LPC1111) on-chip flash programming memory.
􀂄 8 kB, 4 kB, or 2 kB SRAM.
􀂄 In-System Programming (ISP) and In-Application Programming (IAP) via on-chip bootloader software.
􀂄 Serial interfaces:
􀂋 UART with fractional baud rate generation, internal FIFO, and RS-485 support.
􀂋 Two SPI controllers with SSP features and with FIFO and multi-protocol capabilities (second SPI on LQFP48 and PLCC44 packages only).
􀂋 I2C-bus interface supporting full I2C-bus specification and Fast-mode Plus with a data rate of 1 Mbit/s with multiple address recognition and monitor mode.
􀂄 Other peripherals:
􀂋 Up to 42 General Purpose I/O (GPIO) pins with configurable pull-up/pull-down resistors.
􀂋 Four general purpose timers/counters with a total of four capture inputs and 13 match outputs.
􀂋 Programmable WatchDog Timer (WDT).
􀂋 System tick timer.
􀂄 Serial Wire Debug.
􀂄 High-current output driver (20 mA) on one pin.
􀂄 High-current sink drivers (20 mA) on two I2C-bus pins in Fast-mode Plus.
􀂄 Integrated PMU (Power Management Unit) to minimize power consumption during Sleep, Deep-sleep, and Deep power-down modes.
􀂄 Three reduced power modes: Sleep, Deep-sleep, and Deep power-down.
􀂄 Single 3.3 V power supply (1.8 V to 3.6 V).
􀂄 10-bit ADC with input multiplexing among 8 pins.
􀂄 GPIO pins can be used as edge and level sensitive interrupt sources.
􀂄 Clock output function with divider that can reflect the system oscillator clock, IRC clock, CPU clock, and the Watchdog clock.
􀂄 Processor wake-up from Deep-sleep mode via a dedicated start logic using up to 13 of the functional pins.
􀂄 Brownout detect with four separate thresholds for interrupt and one threshold for forced reset.
􀂄 Power-On Reset (POR).
􀂄 Crystal oscillator with an operating range of 1 MHz to 25 MHz.
􀂄 12 MHz internal RC oscillator trimmed to 1 % accuracy that can optionally be used as a system clock.
􀂄 PLL allows CPU operation up to the maximum CPU rate without the need for a high-frequency crystal. May be run from the main oscillator, the internal RC oscillator, or the watchdog oscillator.
􀂄 Available as 48-pin LQFP package, 33-pin HVQFN package, and 44-pin PLCC Package.
LPC1111/12/13/14应用:
􀂄 eMetering
􀂄 Lighting
􀂄 Industrial networking
􀂄 Alarm systems
􀂄 White goods
图1.LPC1111/12/13/14方框图
The LPC11xx are ARM Cortex-M0 based microcontrollers (designed for 8/16-bit microcontroller applications) for embedded applications featuring a high level of integration and low power consumption. The LPC11xx operate at CPU frequencies of up to 50 MHz. The peripheral complement of the LPC11xx series includes up to 32 KB of flash memory, up to 8 KB of data memory, one Fast-mode Plus I2C-bus interface, one RS-485/EIA-485 UART, up to two SPI interfaces with SSP features, four general purpose timers, a 10-bit ADC, and up to 42 general purpose I/O pins.
The LPC11xx operates in the –65 to +150 °C temperature range, from a 1.8 to 3.6 V power supply. A comprehensive set of power-saving mode allows the design of low-power applications.
LPC1114入门套件
The LPC1114 Starter Kit is a brand new, cost-effective but high-performance evaluation tool of the ARM Cortex-M0 based LPC11xx controller family from NXP, allowing you to create and test working programs for this advanced architecture. The board has a wide range of interfaces making it a great starting point for your next Cortex-M0 project.
You can use the Cortex-M0 based LPC1114 KIT to generate and test application programs for the NXP LPC11xx microcontroller family. With this hands-on process, you can determine the hardware and software requirements for current and future product development.
图2.NXP LPC1114入门套件外形图
图3.NXP LPC1114入门套件电路图(1)
图4.NXP LPC1114入门套件电路图(2)
详情请见:
20104281181760271[1].pdf (1.27 MB, 下载次数: 4) 和
EM-LPC1100_Schematic[1].pdf (93.21 KB, 下载次数: 0) |
