NXP LPC1857 ARM Cortex-M3 32位MCU开发方案
关键词: 32位MCU , arm , Cortex-M3 , LPC1857 , NXP
NXP公司的LPC1857/53是基于ARM Cortex-M3内的 32位MCU,具有高达1MB闪存,136kB SRAM,以太网和两个高速USB以及LCDEMC等。ARM Cortex-M3处理器工作频率高达180MHz,内置了支持8个区域的存储器保护单元(MPU)和嵌套向量中断控制器 (NVIC),具有丰富外设,主要用在工业控制,RFID阅读器,电子测量仪器,消费类电子和白色家电。本文介绍了LPC1857/53主要特性和优势,方框图,以及Hitex LPC1850评估板主要特性,电路图和元件布局图。
The LPC1857/53 are ARM Cortex-M3 based microcontrollers for embedded applications.
The ARM Cortex-M3 is a next generation core that offers system enhancements such as low power consumption, enhanced debug features, and a high level of support block integration.
The LPC1857/53 operate at CPU frequencies of up to 180 MHz. The ARM Cortex-M3 CPU incorporates a 3-stage pipeline and uses a Harvard architecture with separate local instruction and data buses as well as a third bus for peripherals. The ARM Cortex-M3 CPU also includes an internal prefetch unit that supports speculative branching.
The LPC1857/53 include up to 1 MB of flash and 136 kB of on-chip SRAM, 16 kB of EEPROM memory, a quad SPI Flash Interface (SPIFI), a State Configurable Timer (SCT)subsystem, two High-speed USB controllers, Ethernet, LCD, an external memory controller, and multiple digital and analog peripherals.
LPC1857/53主要特性和优势:
 Processor core
 ARM Cortex-M3 processor, running at CPU frequencies of up to 180 MHz.
 ARM Cortex-M3 built-in Memory Protection Unit (MPU) supporting eight regions.
 ARM Cortex-M3 built-in Nested Vectored Interrupt Controller (NVIC).
 Non-maskable Interrupt (NMI) input.
 JTAG and Serial Wire Debug, serial trace, eight breakpoints, and four watch points.
 Enhanced Trace Module (ETM) and Enhanced Trace Buffer (ETB) support.
 System tick timer.
 On-chip memory
 Up to 1 MB on-chip dual bank flash memory with flash accelerator.
 16 kB on-chip EEPROM data memory.
 136 kB SRAM for code and data use.
 Multiple SRAM blocks with separate bus access.
 64 kB ROM containing boot code and on-chip software drivers.
 32-bit One-Time Programmable (OTP) memory for general-purpose use.
 Clock generation unit
 Crystal oscillator with an operating range of 1 MHz to 25 MHz.
 12 MHz internal RC oscillator trimmed to 1 % accuracy over temperature and voltage.
 Ultra-low power RTC crystal oscillator.
 Three PLLs allow CPU operation up to the maximum CPU rate without the need for a high-frequency crystal. The second PLL is dedicated to the High-speed USB, the third PLL can be used as audio PLL.
 Clock output.
 Configurable digital peripherals:
 State Configurable Timer (SCT) subsystem on AHB.
 Global Input Multiplexer Array (GIMA) allows to cross-connect multiple inputs and outputs to event driven peripherals like timers, SCT, and ADC0/1.
 Serial interfaces:
 Quad SPI Flash Interface (SPIFI) with 1-, 2-, or 4-bit data at rates of up to 40 MB per second.
 10/100T Ethernet MAC with RMII and MII interfaces and DMA support for high throughput at low CPU load. Support for IEEE 1588 time stamping/advanced time stamping (IEEE 1588-2008 v2).
 One High-speed USB 2.0 Host/Device/OTG interface with DMA support and on-chip high-speed PHY (USB0).
 One High-speed USB 2.0 Host/Device interface with DMA support, on-chip full-speed PHY and ULPI interface to external high-speed PHY (USB1).
 USB interface electrical test software included in ROM USB stack.
 Four 550 UARTs with DMA support: one UART with full modem interface; one UART with IrDA interface; three USARTs support UART synchronous mode and a smart card interface conforming to ISO7816 specification.
 Two C_CAN 2.0B controllers with one channel each.
 Two SSP controllers with FIFO and multi-protocol support. Both SSPs with DMA support.
 One Fast-mode Plus I2C-bus interface with monitor mode and with open-drain I/O pins conforming to the full I2C-bus specification. Supports data rates of up to 1 Mbit/s.
 One standard I2C-bus interface with monitor mode and standard I/O pins.
 Two I2S interfaces with DMA support, each with one input and one output.
 Digital peripherals:
 External Memory Controller (EMC) supporting external SRAM, ROM, NOR flash, and SDRAM devices.
 LCD controller with DMA support and a programmable display resolution of up to 1024H  768V. Supports monochrome and color STN panels and TFT color panels; supports 1/2/4/8 bpp Color Look-Up Table (CLUT) and 16/24-bit direct pixel mapping.
 SD/MMC card interface.
 Eight-channel General-Purpose DMA (GPDMA) controller can access all memories on the AHB and all DMA-capable AHB slaves.
 Up to 164 General-Purpose Input/Output (GPIO) pins with configurable pull-up/pull-down resistors and open-drain modes.
 GPIO registers are located on the AHB for fast access. GPIO ports have DMA support.
 Up to 8 GPIO pins can be selected from all GPIO pins as edge and level sensitive interrupt sources.
 Two GPIO group interrupt modules enable an interrupt based on a programmable pattern of input states of a group of GPIO pins.
 Four general-purpose timer/counters with capture and match capabilities.
 One motor control PWM for three-phase motor control.
 One Quadrature Encoder Interface (QEI).
 Repetitive Interrupt timer (RI timer).
 Windowed watchdog timer.
 Ultra-low power Real-Time Clock (RTC) on separate power domain with 256 bytes of battery powered backup registers.
 Event recorder with three inputs to record event identification and event time; can be battery powered.
 Alarm timer; can be battery powered.
 Analog peripherals:
 One 10-bit DAC with DMA support and a data conversion rate of 400 kSamples/s.
 Two 10-bit ADCs with DMA support and a data conversion rate of 400 kSamples/s. Decryption:
 Hardware-based AES decryption programmable through an on-chip API.
 Two 128-bit secure OTP memories for AES key storage and customer use.
 Random Number Generator (RNG) accessible through AES API.
 Unique ID for each device.
 Power:
 Single 3.3 V (2.2 V to 3.6 V) power supply with on-chip internal voltage regulator for the core supply and the RTC power domain.
 RTC power domain can be powered separately by a 3 V battery supply.
 Four reduced power modes: Sleep, Deep-sleep, Power-down, and Deep power-down.
 Processor wake-up from Sleep mode via wake-up interrupts from various peripherals.
 Wake-up from Deep-sleep, Power-down, and Deep power-down modes via external interrupts and interrupts generated by battery powered blocks in the RTC power domain.
 Brownout detect with four separate thresholds for interrupt and forced reset.
 Power-On Reset (POR).
 Available as LQFP208, LBGA256, or TFBGA180 packages.
LPC1857/53应用:
 Industrial
 RFID readers
 Consumer
 e-Metering
 White goods
图1。LPC1857/53方框图
Hitex LPC1850评估板
The Hitex LPC1850 Eval board allows you to quickly and easily evaluate the LPC1800 family of microcontrollers. The microcontroller, board, and the accompanying features make it a great starting point for your next Cortex-M3 project.
Populated with the LPC1850 to demonstrate LPC1800 features, the LPC1850 offers industry leading performance, large internal memories and advanced peripherals.
Hitex LPC1850评估板主要特性:
The evaluation board has the following features:
- CPU: LPC1850 (ARM Cortex-M3)
- Power-over-Ethernet
- Ready for energy consumption analysis with PowerScale of the complete board, the CPU-core and other peripherals
- SDRAM, SRAM, parallel flash, NAND flash, qSPI flash
- Temperature sensor, SD card, media-connector
- CAN, UART, Ethernet, USB (Host, Device, OTG)
- Debug with standard ARM JTAG and JTAG + Trace connector
- Ready for Jennic ZigBee module
- Small onboard display and NXP standard display / LCD interface
- Touch buttons and LEDs
- Wrap field for user circuits
- Audio IN and OUT, microphone IN, headphones OUT and a D-Class amplifier
- Ready for 4x ADC1415 analog-to-digital converters with user filtering option
图2。Hitex LPC1850评估板外形图
图3。Hitex LPC1850评估板电路图(1)
图4。Hitex LPC1850评估板电路图(2)
图5。Hitex LPC1850评估板电路图(3)
图6。Hitex LPC1850评估板电路图(4)
图7。Hitex LPC1850评估板电路图(5)
图8。Hitex LPC1850评估板电路图(6)
图9。Hitex LPC1850评估板电路图(7)
图10。Hitex LPC1850评估板电路图(8)
图11。Hitex LPC1850评估板PCB元件布局图
详情请见:
LPC1857_53[1].pdf (1.48 MB, 下载次数: 1)
Hitex_LPC1850_Eval_Board_Schematics[1].pdf (245.67 KB, 下载次数: 1)
