三:信号阻塞及信号集操作#include "signal.h"#include "unistd.h"static void my_op(int);main(){ sigset_t new_mask,old_mask,pending_mask; struct sigaction act; sigemptyset(&act.sa_mask); act.sa_flags=SA_SIGINFO; act.sa_sigaction=(void*)my_op; if(sigaction(SIGRTMIN+10,&act,NULL)) printf("install signal SIGRTMIN+10 error\n"); sigemptyset(&new_mask); sigaddset(&new_mask,SIGRTMIN+10); if(sigprocmask(SIG_BLOCK, &new_mask,&old_mask)) printf("block signal SIGRTMIN+10 error\n"); sleep(10); printf("now begin to get pending mask and unblock SIGRTMIN+10\n"); if(sigpending(&pending_mask)<0) printf("get pending mask error\n"); if(sigismember(&pending_mask,SIGRTMIN+10)) printf("signal SIGRTMIN+10 is pending\n"); if(sigprocmask(SIG_SETMASK,&old_mask,NULL)<0) printf("unblock signal error\n"); printf("signal unblocked\n"); sleep(10);}static void my_op(int signum){ printf("receive signal %d \n",signum);}编译该程序,并以后台方式运行。在另一终端向该进程发送信号(运行kill -s 42 pid,SIGRTMIN+10为42),查看结果可以看出几个关键函数的运行机制,信号集相关操作比较简单。注:在上面几个实例中,使用了printf()函数,只是作为诊断工具,pringf()函数是不可重入的,不应在信号处理函数中使用。结束语:系统地对linux信号机制进行分析、总结使我受益匪浅!感谢王小乐等网友的支持!Comments and suggestions are greatly welcome! 附录1:用sigqueue实现的命令行信号发送程序sigqueuesend,命令行第二个参数是发送的信号值,第三个参数是接收该信号的进程ID,可以配合实例一使用:#include <signal.h>#include <sys/types.h>#include <unistd.h>int main(int argc,char**argv){ pid_t pid; int sig; sig=atoi(argv[1]); pid=atoi(argv[2]); sigqueue(pid,sig,NULL); sleep(2);} |
