-- WARNING: Do NOT edit the input and output ports in this file in a text -- editor if you plan to continue editing the block that represents it in -- the Block Editor! File corruption is VERY likely to occur. -- Copyright (C) 1991-2005 Altera Corporation -- Your use of Altera Corporation's design tools, logic functions -- and other software and tools, and its AMPP partner logic -- functions, and any output files any of the foregoing -- (including device programming or simulation files), and any -- associated documentation or information are expressly subject -- to the terms and conditions of the Altera Program License -- Subscription Agreement, Altera MegaCore Function License -- Agreement, or other applicable license agreement, including, -- without limitation, that your use is for the sole purpose of -- programming logic devices manufactured by Altera and sold by -- Altera or its authorized distributors. Please refer to the -- applicable agreement for further details. -- Generated by Quartus II Version 5.1 (Build Build 176 10/26/2005) -- Created on Sat Jan 06 00:37:33 2007
LIBRARY ieee; USE ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; -- Entity Declaration ENTITY ag IS -- {{ALTERA_IO_BEGIN}} DO NOT REMOVE THIS LINE!  ORT ( clk : IN STD_LOGIC; dout : OUT STD_LOGIC_VECTOR(18 downto 0) ); -- {{ALTERA_IO_END}} DO NOT REMOVE THIS LINE! END ag; -- Architecture Body
ARCHITECTURE ag_architecture OF ag IS BEGIN process(clk) variable count:integer range 0 to 19; variable c:std_logic_vector(18 downto 0); begin if(clk'event and clk='0')then case count is when 19=>count:=0; c:="0000000000000000001"; when others=>c:=(others=>'0'); c(count):='1'; count:=count+1; end case; dout<=c; end if; end process; END ag_architecture; 这个你可以试一下,另外你可以试一下把tmp<=tmp+tmp;改成c:=c+c;tmp<=c;--c是变量,
