问题:下载程序后只能进行一次AD转换 调节所测电压不会改变显示 重新下载程序后会改变数值 求解 不知是哪个配置出了问题
while(1)
            //AdcRegs.ADCTRL2.all = 0x4000; //reset
     //AdcRegs.ADCTRL2.all = 0x2000; //software begin
            adc_set( );
            AdcRegs.ADCTRL2.bit.RST_SEQ1 = 1;         // Reset SEQ1
     AdcRegs.ADCTRL2.bit.SOC_SEQ1=1;
    display(result*3.0/4096.0);
    AdcRegs.ADCST.bit.INT_SEQ1_CLR = 1;
    delay();
void  adc_set(void )
    InitAdc();  // For this example, init the ADC
   AdcRegs.ADCTRL1.bit.ACQ_PS = 0x01;
   AdcRegs.ADCTRL3.bit.ADCCLKPS = 0x3;
   AdcRegs.ADCTRL1.bit.SEQ_CASC = 0;        // 1  Cascaded mode
   AdcRegs.ADCTRL1.bit.CONT_RUN=1;
   AdcRegs.ADCTRL1.bit.SEQ_OVRD=1;
   AdcRegs.ADCCHSELSEQ1.bit.CONV00 = 0x04;
         // Setup continuous run
    // Step 5. User specific code, enable interrupts:
   // Start SEQ1
        AdcRegs.ADCTRL2.all = 0x2800; //software begin
        while  (AdcRegs.ADCST.bit.INT_SEQ1== 0) { }   // Wait for interrupt
        result =((AdcRegs.ADCRESULT0>>4) );
        //display(result*3.3/4096.0);
         AdcRegs.ADCTRL1.bit.RESET = 1;
