/* C标志符命名源程序*/
#include <stdio.h>
#include <string.h>
#include <ctype.h>
#include <malloc.h>
char* IsLegal(char* CheckWord);
char* ErrorMessages[]={ /*错误信息列表*/
"无错误!",
"1 首字符只能是字母或下划线!",
"2 常、变量只能由字母、下划线和数字构成!",
"3 常、变量标识不能用C语言关键字!",
"4 常、变量标识不能用C语言函数!",
"内存不够!"
void main(void)
char *Prompt="C语言标志符的命名要遵守以下原则:";
char *TestWord;
int i;
TestWord = (char *)malloc( sizeof(char)*32 ); /*TestWord存放用户输入*/
if(!TestWord )
return;
/*显示部分提示信息*/
puts(Prompt);
for( i=1 ;i<=4;i++){
puts( ErrorMessages );
puts("");
while(1){
printf("\n\n请输入一个标志符(大写的Q退出) :");/*提示*/
scanf("%s",TestWord); /*得到用户输入*/
if( (toupper)(TestWord[0])=='Q' )
break;/*循环出口*/
printf("\n%s %s",TestWord,IsLegal(TestWord)); /*判定标志符的合法性*/
free( TestWord );
/*此函数检验标志符命名的合法性*/
char*KeyWords[]={"auto","break","case","char","continue","const","default",
"do","double","else","enum","extern","float","for","goto",
"if","int","long","noalias","register","return","short",
"signed","sizeof","static","struct","switch","typedef",
"union","unsigned","void","volatile","while","defined",
"define","undef","include","ifdef","ifndef","endif","line",
"error","elif","pragma"};/*C关键字列表*/
char*Functions[]={"close","creat","eof","fclose","fcloseall","feof","fopen",
"ferror","fgetchar","fgets","fprintf","fputc","fputchar",
"fseek","get","putch","putc","printf","open","putchar",
"puts","read","scanf","abs","acos","asin","math","atan",
"atan2","atof","atoi","atol","ceil","dos","cosh","ecvt",
"exp","fabs","floor","fmod","frexp","itoa","labs","ldexp",
"log","log10","modf","pow","rand","sin","sqrt","srand",
"strtod","strlol","tan","tanh","ultoa","memset","strcpy",
"struct","strchr","strcmp","calloc","isalnum","isalpha",
"toascii","tolower","tollpper","exit"};/*C主要函数列表*/
char* Others="_";/*'_'也可以用于关键字,但我们不推荐您使用!*/
intWordLength,i;
char* WordTemp;
WordTemp = (char*)malloc( 32 *sizeof(char ) );
if(!WordTemp ) return ErrorMessages[5];
WordLength=strlen(CheckWord);
/*检查标志符命名原则1*/
if((isalpha(CheckWord[0])==0)&&(CheckWord[0]!=Others[0]))
returnErrorMessages[1];
/*检查标志符命名原则2*/
for(i=0;i<WordLength;i++)
if((isalnum(CheckWord)==0)&&(CheckWord!=Others[0]))
return ErrorMessages[2];
/*检查标志符命名原则3*/
for(i=0;i<44;i++)
if(!strcmp(CheckWord,KeyWords))
return ErrorMessages[3];
i=0;
for(i=0;i<69;i++) /*检查标志符命名原则4*/
if(!strcmp(CheckWord,Functions))
return ErrorMessages[4];
free(WordTemp);
return ErrorMessages[0];
