#include <stdio.h>
#include <conio.h>
int main(void)
char label[20];
char name[20];
int entries = 0;
int loop, age;
double salary;
struct Entry_struct
char name[20];
int age;
float salary;
}entry[20];
/* Input a label as a string of charactersrestricting to 20 characters */
printf("\n\nPlease enter a label for the chart: ");
scanf("%20s", label);
fflush(stdin); /* flush the inputstream in case of bad input */
/* Input number of entries as an integer */
printf("How many entries will there be? (less than 20) ");
scanf("%d", &entries);
fflush(stdin); /* flush theinput stream in case of bad input */
/* input a name restricting input to onlyletters upper or lower case */
for (loop=0;loop<entries;++loop)
printf("Entry %d\n", loop);
printf(" Name : ");
scanf("%s", &entry[loop].name);
/* input an age as an integer */
printf(" Age : ");
scanf("%d", &entry[loop].age);
/* input a salary as a float */
printf(" Salary : ");
scanf("%f", &entry[loop].salary);
fflush(stdin); /* flush the input stream in case of bad input */
/* Input a name, age and salary as astring, integer, and double */
printf("\nPlease enter your name, age and salary\n");
scanf("%20s %d %lf", name, &age, &salary);
/* Print out the data that was input */
printf("\n\nTable %s\n",label);
printf("Compiled by %s age%d $%15.2lf\n", name, age, salary);
printf("-----------------------------------------------------\n");
printf("%4d | %20s | %5d | %15.2lf\n",
loop + 1,
entry[loop].name,
entry[loop].age,
return 0;
