#include <stdio.h>
#define TYPE struct stu
#define LEN sizeof(struct stu)
struct stu
int num;
int age;
struct stu *next;
TYPE * creatlink(int n);
TYPE * deletelink(TYPE * head,int num);
TYPE * insertlink(TYPE * head,TYPE * pi);
void printlink(TYPE * head);
void destroylink( TYPE * head );
void main(void)
TYPE *head=NULL,*pnum=NULL;
int n=3,num;
/* 创建一个含 n 个节点的链表 */
printf("input number of node:");
head=creatlink(n);
printlink(head);
/* 删除链表中值为 num 的节点 */
printf("Input the deleted number:");
scanf("%d",&num);
head=deletelink(head,num);
printlink(head);
/* 在链表中插入一个节点 */
printf("Insert a record\n");
pnum=(TYPE *)malloc(LEN);
if(pnum==NULL)
printf("Pointer is NULL--memory alloc fail!");
printf("Input the inserted number:");
scanf("%d",&pnum->num);
printf("Input the inserted age:");
scanf("%d",&pnum->age);
head=insertlink(head,pnum);
printlink( head );
/* 销毁链表, 释放动态分配的内存 */
destroylink( head );
TYPE *head=NULL, *pf, *pb;
int i;
for(i=0;i<n;i++)
pb=(TYPE *)malloc(LEN);
printf("record%d\n",i);
printf("input Number:");
scanf("%d",&pb->num);
printf("input age:");
scanf("%d",&pb->age);
if(i==0)
pf=head=pb;
else
pf->next=pb;
pb->next=NULL;
pf=pb;
return(head);
TYPE *pf, *pb;
if(head==NULL)
printf("\nempty list!\n");
return NULL;
pb=head;
while (pb->num!=num && pb->next!=NULL)
pf=pb;
pb=pb->next;
if(pb->num==num)
if(pb==head)
head=pb->next;
else
pf->next=pb->next;
free(pb);
printf("The node is deleted\n");
else
printf("The node not been found!\n");
return head;
/* 在链表中插入一个节点 */
TYPE *pb, *pf;
pb=head;
if(head==NULL)
head=pi;
pi->next=NULL;
else
while((pi->num > pb->num)&&(pb->next!=NULL))
pf=pb;
pb=pb->next;
if(pi->num <= pb->num)
if(head==pb)
head=pi;
else
pf->next=pi;
pi->next=pb;
else
pb->next=pi;
pi->next=NULL;
return head;
/* 打印链表中各节点信息 */
printf("Number\t\tAge\n");
while(head!=NULL)
printf("%d\t\t%d\n",head->num,head->age);
head=head->next;
void destroylink(TYPE * head)
TYPE *p, *q;
p= head;
while( p != NULL )
q = p->next;
free(p);
p = q;
