CADENCE的导入表格后出现的错误.请帮忙.谢谢.
我做好了一个电路图在ORCAD中,然后把元件封装做好并在原理图中对应好.然后生成NETLIST,导入ALLEGRO时,发现只有电阻的封装可以放置,电容和二极管的封装是空的.这是怎么回事呢?我一直不明白,只有电阻的封装好用,别的器件的封装是空的.请帮忙给指导下,谢谢.急.
出现下面的情况提示,我没有看出来怎么修改.
#1   ERROR(305) Device/Symbol check error detected.
Symbol 'D0805' for device 'CA3039/TO_3_D0805_CA3039/TO' is missing pin '8'.
Symbol 'D0805' for device 'CA3039/TO_3_D0805_CA3039/TO' is missing pin '7'.
Symbol 'D0805' for device 'CA3039/TO_3_D0805_CA3039/TO' is missing pin '5'.
Symbol 'D0805' for device 'CA3039/TO_3_D0805_CA3039/TO' is missing pin '6'.
Symbol 'D0805' for device 'CA3039/TO_3_D0805_CA3039/TO' is missing pin '4'.
Symbol 'D0805' for device 'CA3039/TO_3_D0805_CA3039/TO' is missing pin '3'.
Symbol 'D0805' for device 'CA3039/TO_3_D0805_CA3039/TO' is missing pin '12'.
Symbol 'D0805' for device 'CA3039/TO_3_D0805_CA3039/TO' is missing pin '11'.
Symbol 'D0805' for device 'CA3039/TO_3_D0805_CA3039/TO' is missing pin '9'.
Symbol 'D0805' for device 'CA3039/TO_3_D0805_CA3039/TO' is missing pin '10'.
[此贴子已经被作者于2007-1-9 16:25:50编辑过]
做个快乐的技术开发者!
Symbol 'D0805'的PIN没有找到,可能原因是没有相应的PAD或PAD是经过CHECK。
我是主持人,煸情功夫一流。我是工程师,刻苦学习一生。我是海王星,透明蓝色一体。因为有了你,我就一通百通。
谢谢.我做好了.
做个快乐的技术开发者!
