C语言经典算法之逆波兰计算器
C语言经典算法之逆波兰计算器
#include <stdio.h>
#include <stdlib.h>
#include <ctype.h>
#define MAXOP  100
#define NUMBER  '0'
int getop (char [] );
void push (double);
double pop(void);
int getch(void);
void ungetch(int);
int getop(char s[])
int i,c;
while ((s[0]=c=getch())==' '|| c=='\t');
       s[1]='\0';
if(!isdigit(c)&&c!='.')
return c;
       i=0;
if(isdigit(c))
while(isdigit(s[++i]=c=getch()));
if (c=='.')
    while (isdigit(s[++i]=c=getch()));
s[i]='\0';
if (c!=EOF)
ungetch(c);
return NUMBER;
#define BUFSIZE 100
char buf[BUFSIZE];
int bufp=0;
int getch(void)
return(bufp>0)? buf[--bufp]:getchar();
void ungetch(int c)
if (bufp>=BUFSIZE)
  printf("ungetch:too manycharacters\n");
else
buf[bufp++]=c;
main()
int type;
double op2;
char s[MAXOP];
while ((type=getop(s))!=EOF)  {
switch (type)  {
         case NUMBER:
              push(atof(s));
     break;
         case '+':
              push(pop()+pop());
              break;
         case '*':
              push(pop()*pop());
              break;
         case '-':
              op2=pop();
              push(pop()-op2);
              break;
                   case'/':
              op2=pop();
              if (op2!=0.0)
                  push(pop()/op2);
              else
                  printf("error:zerodivisor\n");
                  break;
         /*case '/n':
                 printf("\t%.8g\n",pop());
                  break;*/
          case 0x0a:
                  break;
         default:
                  printf("error:unknowncommand %s\n",s);
                  break;
return 0;
#define MAXVAL 100
int sp=0;
double val[MAXVAL];
void push(double f)
if (sp<MAXVAL)
       val[sp++]=f;
else
printf("error:strackfull,can't push %g\n",f);
double pop(void)
if (sp>0)
return val[--sp];
else {
printf("error:stack empty\n");
return 0.0;
