以0805以例,有如下信息:(找一个Symbol看看,也可以用向导做) LISTING: 10 element(s) Item 1 < STAND-ALONE PIN > class PIN location-xy: (-45.00 0.00) pin number: 1 not on a net padstack name: SMD60REC50 padstack defined only on TOP padstack rotation: 0.000 degrees Number of connections: 0 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Item 2 < FILLED RECTANGLE > class PACKAGE GEOMETRY subclass PLACE_BOUND_TOP xy-lower xy-upper Rectangle Top: (-85.00 35.00) (85.00 35.00) Rectangle Bottom: (-85.00 -35.00) (85.00 -35.00) Height: 70.00 mils Width: 170.00 mils Area: 0.0119 (sq in) rotation: 0.000 degrees ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Item 3 < RECTANGLE > class PACKAGE GEOMETRY subclass ASSEMBLY_TOP Rectangle Top: (-85.00 35.00) (85.00 35.00) Rectangle Bottom: (-85.00 -35.00) (85.00 -35.00) Height: 70.00 mils Width: 170.00 mils Area: 0.0119 (sq in) rotation: 0.000 degrees line font: Solid ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Item 4 < LINE > class PACKAGE GEOMETRY subclass SILKSCREEN_TOP segment:xy (-85.00 35.00) xy (-85.00 -35.00) width (7.00) font (Solid) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Item 5 < LINE > class PACKAGE GEOMETRY subclass SILKSCREEN_TOP segment:xy (-85.00 -35.00) xy (85.00 -35.00) width (7.00) font (Solid) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Item 6 < LINE > class PACKAGE GEOMETRY subclass SILKSCREEN_TOP segment:xy (85.00 35.00) xy (-85.00 35.00) width (7.00) font (Solid) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Item 7 < TEXT > class REF DES subclass ASSEMBLY_TOP TEXT CONTENTS: "R*" origin-xy: (-75.00 50.00) rotation: 0.000 degrees not_mirrored justification: left TEXT_BLOCK# 2 font: ANSI height: 31.00 width: 23.00 photoplot width: 0.00 spacing: 8.00 line spacing: 39.00 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Item 8 < TEXT > class REF DES subclass SILKSCREEN_TOP TEXT CONTENTS: "R*" origin-xy: (-75.00 50.00) rotation: 0.000 degrees not_mirrored justification: left TEXT_BLOCK# 2 font: ANSI height: 31.00 width: 23.00 photoplot width: 0.00 spacing: 8.00 line spacing: 39.00 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Item 9 < STAND-ALONE PIN > class PIN location-xy: (45.00 0.00) pin number: 2 not on a net padstack name: SMD60REC50 padstack defined only on TOP padstack rotation: 0.000 degrees Number of connections: 0 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Item 10 < LINE > class PACKAGE GEOMETRY subclass SILKSCREEN_TOP segment:xy (85.00 -35.00) xy (85.00 35.00) width (7.00) font (Solid) ~ ~ ~ ~ ~ ~ ~end-of-file~ ~ ~ ~ ~ ~ ~
