MiniGUI1.33开源版在ARMSYS2410-B上的移植
- 来自
- 燕山大学
0 。准备
(a) 建立如下目录:
minigui
|--build_x86 /建立PC上运行的MiniGUI
|--build_arm /建立ARM上运行的MiniGUI
|--tarball /所有的包资源存放点
(b) download MiniGUI:
从www.minigui.com下载libminigui-1.3.3.tar.gz 和minigui-res-1.3.3.tar.gz并且放
tarball目录
(起始目录:minigui)
#cd build_x86
#tar zxvf ../tarball/libminigui-1.3.3.tar.gz
#tar zxvf ../tarball/minigui-res-1.3.3.tar.gz
#cd ../build_arm
#cd ..
(c) download and install qvfb:
从www.minigui.com下载qvfb-1.0.tar.gz,放入tarball目录
#cd build_x86
#tar zxvf ../tarball/qvfb-1.0.tar.gz
#cd qvfb-1.0
#./configure
#make
#make install
#cd ..
(d) 建立范例程序:
test.c
--------------------------------------------------------------------------test.c begin
#include <minigui/common.h>
#include <minigui/minigui.h>
#include <minigui/gdi.h>
#include <minigui/window.h>
#include <minigui/control.h>
#define MWINDOW_LX 10
#define MWINDOW_TY 50
#define MWINDOW_RX 230
#define MWINDOW_BY 180
static char * hello_str = "HelloMiniGUI!";
HWND hMainWnd;
static int WinProc (HWND hWnd, int message, WPARAM wParam, LPARAM lParam)
HDC hdc;
RECT rc;
switch (message)
case MSG_PAINT :
hdc = BeginPaint(hWnd);
GetClientRect(hWnd, &rc);
DrawText(hdc, hello_str, -1, &rc, DT_LEFT);
EndPaint(hWnd, hdc);
break;
case MSG_CLOSE :
DestroyMainWindow(hWnd);
PostQuitMessage(hWnd);
break;
default :
return(DefaultMainWinProc(hWnd, message, wParam, lParam));
return(0);
int InitMainWindow(void)
MAINWINCREATE window_info;
window_info.dwStyle = WS_VISIBLE | WS_BORDER | WS_CAPTION;
window_info.dwExStyle = WS_EX_NONE;
window_info.spCaption = "MiniGUI";
window_info.hMenu = 0;
window_info.hCursor = GetSystemCursor(0);
window_info.hIcon = 0;
window_info.MainWindowProc = WinProc;
window_info.lx = MWINDOW_LX;
window_info.ty = MWINDOW_TY;
window_info.rx = MWINDOW_RX;
window_info.by = MWINDOW_BY;
window_info.iBkColor = COLOR_lightwhite;
window_info.dwAddData = 0;
window_info.hHosting = HWND_DESKTOP;
hMainWnd = CreateMainWindow(&window_info);
if (hMainWnd == HWND_INVALID)
return(0);
else
return(1);
int MiniGUIMain (int argc, const char ** argv)
MSG Msg;
#ifdef _LITE_VERSION
SetDesktopRect(0, 0, 800, 600);
#endif
InitMainWindow();
ShowWindow(hMainWnd, SW_SHOWNORMAL);
while (GetMessage(&Msg, hMainWnd))
TranslateMessage(&Msg);
DispatchMessage(&Msg);
MainWindowThreadCleanup(hMainWnd);
return(0);
#ifndef _LITE_VERSION
#include <minigui/dti.c>
#endif
--------------------------------------------------------------------------test.c end
1. Build MiniGUI for PC:
(a) build lib
#Cd build_x86
#Cd libminigui-1.3.3
#./configure
#make
#make install
#cd ..
(b) install resource
#cd minigui-res-1.3.3
#make install
#cd ..
(资源被安装到/usr/local/lib/minigui/中)
(c) build and run test
#gcc –o test test.c –lpthread –lminigui –ljpeg –lpng –lz –lttf
把/usr/local/etc/MiniGUI.cfg中[system]组的gal_engine和ial_engine的值都改成qvfb
#qvfb –width 640 –height 480 –depth 16 &
#./test
#cd ..
2. Build MiniGUI for ARM:
(a) build lib
#cd build_arm
#cd libminigui-1.3.3
#make menuconfig
在默认的设置下
将“GAL engine options”中的“NEWGAL”改成“OLDGAL”;
将“Font options”中的最后三项保留,其余全部不选;
将“Image options”中对JPG和PNG的support去掉;
将“Development environment options”中“Compiler”设置成“arm-linux-gcc”,“Path prefix”设置成“/usr/local/arm/2.95.3/arm-linux”(假设交叉编译环境安装在/usr/local/arm)。其余选项全部取默认值。保存修改并退出menuconfig
#make
#make install
#cd ..
(b) build test.c
#arm-linux-gcc –o test test.c –lpthread –lminigui
这样就会产生一个名为test的文件。
(c) 设置root file system
假设已经有一个可以用的root file system
把先前安装在/usr/local/arm/2.95.3/arm-linux/lib下的库文件复制到目标文件系统的/lib目录下。如果分不清楚那个目录下哪些是需要复制的库文件,可以重复一次2.(a)的过程,并且把其中“Path prefix”的值改成你事先建立的一个空的目录的路径。比如,我建立了一个新的目录/root/need,并且把“Path prefix”的值改成了“/root/need”, 那么在执行完2.(a)后,/root/need/lib目录下的所有文件就是我们所需要复制的MiniGUI库文件。(这个办法很冗余-_-)
把/usr/local/etc/MiniGUI.cfg文件复制到目标文件系统的/usr/local/etc/目录下,并且修改该文件,将[system]组中的gal_engine的值改成“fbcon” ial_engine的值改成“console” mdev的值改成“/dev/mouse” mtype的值改成“PS2”,将[fbcon]组中的defaultmode改成“640x480-16bpp”(根据实际情况而定)。
把/usr/local/lib/minigui/res整个目录复制到目标文件系统的/usr/local/lib/minigui中。
最后把刚才编译好的test文件复制到目标文件系统的/bin下面。
(d) 设置鼠标
我的LCD没有带触摸屏,所以要设置鼠标,我的鼠标是USB口的。
修改文件系统的/etc/init.d/rcS,添加一行:“ln /dev/input/mice /dev/mouse”
(e) run
给板子上电,通过minicom执行:
#test &
就能在LCD上看到运行结果了。
本文来源:电子开发网 作者: |
