1.写好了程序不必立刻写入flash中,可挂载在本机上,但出现这种错误: # mount 192.168.2.122:/ /mnt mount: Mounting 192.168.2.122:/ on /mnt failed: No such file or directory 说明nfs没有设置好. 我觉得在装系统时最好全部安装,因为我以前部分安装时,没装tftp,后来又单独安装了tftp的rpm包,试了很多遍,结果还是不能用,全部安装以后 问题解决,我猜想是不是还要装一些关联的库 . 2. 30008000是zImage,30800000是ramdisk在ram中的默认下载地址,可以改变的. 3. Retry count exceeded; starting again NetOurIP =c0a80278 NetServerIP = c0a8027a NetOurGatewayIP = c0a80201 NetOurSubnetMask = ffffff00 ARP broadcast 1 ARP broadcast 2 ARP broadcast 3 ARP broadcast 4 ARP broadcast 5 我遇到的原因是我的IP地址没有设为192.168.2.122.改为192.168.2.122后出现: Retry count exceeded; starting again NetOurIP =c0a80278 NetServerIP = c0a8027a NetOurGatewayIP = c0a80201 NetOurSubnetMask = ffffff00 ARP broadcast 1 ARP broadcast 2 TFTP from server 192.168.2.122;our IP address is 192.168.2.120 Loading: TTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTT 当时试了好多次都这样,但是第二天在试就成功了.百思不得其解向wpq询问知道是网络不流畅,多试几次就好了,T表示timeout 4.进入SMDK2410目录相当于进入PC机的BIOS,故在SMDK2410# 后ifconfig是错误的命令.在SMDK2410# 输入help可以显示可在此目录下使用的命令 5.[root@localhost Images]# ./flash +------------------------------------+ | SEC JTAG FLASH(SJF) v 0.3 | | (S3C2410X & SMDK2410 B/D) | +------------------------------------+ Usage: SJF /f: /d= > No CPU is detected.
[SJF Main Menu] 0:K9S1208 program 1:28F128J3A program 2:Memory Rd/Wr 3:Exit Select the function to test:1 [28F128J3A Flash JTAG Programmer] *** Very Important Notes *** 1. 28F128J3A must be located at 0x08000000. J6 : connect 2-3 pins, J9 : connect 1-2 pins J33 : Open, J34 : Short 2. After programming, 28F128J3A may be located at 0x0. J6 : connect 1-2 pins, J9 : connect 2-3 pins J33 : Short, J34 : Open Source size = 15d54h Available Target Offset Address: 0x0,0x20000,0x40000, ..., 0x1ce0000 Input target address offset [0x?] : 0x08000000 Target base address(0x08000000) = 0x0 Target offset (0x0) = 0x8000000 Target size (0x20000*n) = 0x15d54 Identification check error !! [root@localhost Images]# 开始以为是flash坏了,好害怕,后来才明白是JTAG接触不好.在烧写ppcboot时最好用tftp先下载,实在不行在用JTAG. |
