» Vivado HLS学习资料
Vivado HLS学习资料
pengpengpang
(pengpengpang)
来自
中国
156 小时
来自
中国
pengpengpang
发表于 2014-6-29 21:49
Vivado HLS学习资料
资料
第一, 手边的学习资料。 安装Vivado HLS以后, 既包含了20个design example,50个code example: 附件:[[wysiwyg_imageupload:950:]] 第二, step by step教程 ug871 是xilinx公开提供的HLS教程, 包括11个例子: C ValidationInterface SynthesisArbitrary Precision TypesDesign AnalysisDesign OptimizationRTL VerificationUsing HLS IP in IP IntegratorUsing HLS IP in a Zynq Processor DesignUsing HLS IP in System Generator for DSP ug871 :
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_1/ug871-vivado-high-level-synthesi...
参考设计源代码:
http://www.xilinx.com/cgi-bin/docs/rdoc?v=2013.2;t=vivado+tutorials
附件:[[wysiwyg_imageupload:951:]] 第三, 13个Xilinx专家讲解视频, 包括讲座和演示 地址:
www.xilinx.com/training/vivado
1.
Getting Started with Vivado High-Level Synthesis
2.
Verifying your Vivado HLS Design
3.
Packaging Vivado HLS IP for use from Vivado IP Catalog
4.
Generating Vivado HLS block for use in System Generator for DSP
5.
Generating Vivado HLS pcore for use in Xilinx Platform Studio
6.
Analyzing your Vivado HLS design
7.
Specifying AXI4 interfaces for your Vivado HLS design
8.
Using Vivado HLS C/C++/SystemC block in System Generator
9.
Using Vivado HLS C/C++/SystemC based pcores in XPS
10.
Floating-Point Design with Vivado HLS
11.
Using Vivado HLS SW libraries in your C, C++, SystemC code
12.
Using the Vivado HLS Tcl
interface
13.
Leveraging
OpenCV
and High Level Synthesis with Vivado
第四, 不停更新的武林秘籍
www.xilinx.com/hls
XAPP745 Processor Control of Vivado HLS Designs
XAPP793 Implementing Memory Structures for Video Processing in the Vivado HLS Tool
XAPP599
Floating Point Design with Vivado HLS
XAPP890 Zynq All Programmable SoC Sobel Filter Implementation Using the Vivado HLS
Tool
XAPP1163 - Floating-Point PID Controller Design with Vivado HLS and System Generator for
DSP
XAPP1167
Accelerating OpenCV Applications with Zynq using Vivado HLS Video Libraries
附件:[[wysiwyg_imageupload:952:]]
